Results 1 to 6 of 6
Thread: AE86 (Track) SR20 power.
    Junior Member Jonny_G's Avatar
    Bankstown
    Default AE86 (Track) SR20 power.
    Hi,
    Up for sale is my AE86 - Im pretty sure its ADM originally
    Specs as follows.
    Engine-
    STOCK SR20 blacktop - approx 50,000 K's - (ex 180typeX motor 96') custom engine mounts
    Custom Front Mount (black painted)
    Custom Radiator (Stainless)
    Customs Exhaust Turbo back
    approx. power 179KW @ 10PSI. (a bit over stock boost)
    Running T boost controller (manual) stock ECU (PFC ready!)
    Simota POD.
    Drive-
    SR20 (s13) gearbox - 5 speed (just put in reco'd) (typeX) on custom cross memeber
    Exedy H/D Clutch (semi organic or something?)
    Customs Tailshaft (brand new UNI's)
    Cusco 2way (4.11's) whole diff recently replaced (new axles & all) old diff had stock centre (welded) T series ***Disc Brake rear end***
    Brand new front discs 280mm slotted (T3 - Wilwood Calipers twin pistons)
    Reco'd rear discs & calipers
    Tires- TOYO PROXES RA1 (Semi's 70% left)
    Suspension-
    AJPS fully adjustable Coilovers (front) not sure on spring ratings
    Swaybars F&R - not sure of the size but they're fat i think front is 25 or 26 mm
    Cusco strut brace (front only)
    Cusco Camber Tops
    Tokico rear shocks (adjustable damper)
    Rear Springs (i think 6-8 KG not 100%)
    Ride is tight, awesome handling
    1.11's @ Wakefield. (thats the only time i can remember) ive set times @ Oran Park & EC..when i find them on natsoft will post them.. very quick car though.
    Interior-
    Stripped out from middle back
    Recaro Buckets
    Full harnesses (driver & pass.)
    MoMo Wheel
    Gauges- (all Autometer - Monster tach + dummys light, Oil Press., Water Temp, Volts, A/F Ratio) Defi - Boost Gauge (smoked face)
    Full bolt in cage (Bonds Cage)
    Relocated battery to boot (solid cradle) + isolation switch hanging out the boot =) *see pic*
    **the car is very neat**
    Exterior-
    I won't say the body is immac.. its not
    Paint is good for its age, the hatch needs to be sprayed (its only primered at the moment) its got the odd ding here & there its in GC for its age!
    Colour coded rear bar, duckwing fitted
    Brand new windscreen (needed to have chip free for CAMS regs)
    Advan Oni rims 15x8.5 Rear 15x8 Front
    Chassis got about 300xxx k's on it.
    All electricals are working (minus aircon)
    Car has not been "drifted" while i've owned it.
    Running gear is immac. doesn't blow smoke, doesn't use oil, water, anything.
    I service it after every track meet (once a month)
    Car is awesome fun on the track, handles beautifully, plenty of power backing it, very very quick!
    Was rego'd up until august 08' or something. Rego can be re-done.
    Everything is engineered (got papers) (except the cage) if your looking at regoing it.
    ** I've got a blown SR box that will go with it, good for PP rebuild.
    Looking at $14,000 ono
    Alot of hard work, time & efforts gone into this car
    It's been well looked after
    I also have a car trailer suited if you like...
    Call anytime Location SYD (inner-west)
    Pete, 0412 259 362
    John, 0404 306 096
ID:	616   Click image for larger version.
ID:	617   Click image for larger version.
ID:	618   Click image for larger version.
ID:	619   Click image for larger version.
Name:	resize brakes.jpg
ID:	944   Click image for larger version.
Name:	cage resize.JPG
ID:	945   Click image for larger version.
Name:	Rear Resize.jpg
ID:	946   Click image for larger version.
Name:	Driver side resize.jpg
    Bankstown
    Default Bump.
    BUMP-o
    232 views.... no offers?
    Senior Member angelo's Avatar
    angelo
    nsw
    belmore
    nice car mate, gl with sale!
    If In Doubt, Drift Her Out.
  • #4
    Bankstown
    Updated pics
    BUMp
  • #5
    did u buy this car off a guy name dean
  • #6
    Bankstown
    BUMP -
    Seeing as theres no offers, could be too much $$
    Tell me what its worth people....will re-consider price.
    **When i hear it spool... it makes me droool**
  • Similar Threads
    1. (SA) sr20 Power FC
      By slide wayz in forum Car Parts For Sale
      Last Post: 14th July 2011, 03:38 PM
    2. Replies: 2
      Last Post: 21st February 2011, 05:52 PM
    3. SR20 - AE86 Full Conversion for sale + AE86 Part Out
      By Jonny_G in forum Car Parts For Sale
      Last Post: 30th November 2010, 01:09 PM
    4. Replies: 0
      Last Post: 13th August 2010, 12:32 AM
    5. Setup ae86 with sr20 or s13 with sr20
      By MR 86 in forum Technical - Questions
      Last Post: 5th July 2010, 11:56 AM
