It is best if the strut is "in line" from chassis end to motor end (perpendicular to the crankshaft), but if it's not far out it won't be an issue. I'd say having it bolted to your extractors could be a little too warm.
Also is the strut you're using meant to be an engine damper? If it's just a hatch strut it may not be too good.
