not much to it. pole and hammer
hi guys.
search engine thingy wasnt working
so anyway.
just like some tips and hints on rolling/lipping guards.
do's and dont's.
personal experiences.
cheers.
If you care about your paint work, get a heat gun out and heat the lip area so it doesn't crack the paint easily when you "edit" it.
and if your going to be hitting the lip from the inside with a hammer. make sure you put a brick or a block of wood on the outside of the lip (protect your paint by wrapping it in a rage). that way you wont deform the guard itself, you will only hit the lip up against the block of wood.
also one thing i noticed when i was bashing mine up yesterday, when you fold the lip up it creates a crevice where dirt and moisture can sit. which equals....RUST!!!
so i had an idea, of drilling some holes in the bend of the lip, so if any moisture collects it will attempt to let it out. i dunno how well its gonna work, ill give it a go this arvo....
- Blaise Pascal
Really you should be doing it with a person holding the pole, but i have no friends.
dont worry, i'll hold your pole marvis.
YESS! winner hahaa
ke70dave i put a few tiny holes in before i folded it up and when im bored after ive washed my car ill spray some wd40 or equiv down there. Motorbike habits.
wheelfriends.wordpress.com
yeah standard ae86 guards have some sort of tacky/sticky shit inside the lip try get rid of that beforeu lip guards, thats what keeps inside moist and ends up rusing from inside to out
using a pole will never get good results. as you will struggle to get the lip folded out of the way with out damading, or pulling the guard out further then you want
using a guard roller you can push that lip all the way up and in without really pulling the guard out at all. and if done right wont wreck your paint.
otherwise i'de use the hammer/dolly approach, takes longer, will wreck paint but will get better results then a pole.
pm me if you want more info/someone to do it for you.
-dan
gunner:
ALL DRIFT MODIFICATIONSYou're a fucking idiot, and I am ashamed that you are part of this community. Sure there isn't many tracks, but praticing on the street isn't the alternative.
after i rolled an flared my rears, i ground back the inside as best i could, an put a big smear of rtv silicon all the way down to the bottom of the fold, then neatly blended it in. This way no water should get in or out under ur lip
just need to go nice an slow when doing it too, stretch the metal slowly not too quick. aim for about an hours of hitting each side, its not a 5 minute job
in theory by skinny white boy
My 4agte hatch
http://www.ae86drivingclub.com.au/fo...ead.php?t=8583
my 70 wagon
http://www.ae86drivingclub.com.au/fo...ead.php?t=9525
my NA 86
http://www.ae86drivingclub.com.au/fo...s-2nd-sprinter
My Indonesian KE70 DX
http://www.ae86drivingclub.com.au/fo...nesian-KE70-DX
