Results 1 to 7 of 7
Thread: dizzy oil leakin.. cont
    Junior Member redhachiboy's Avatar
    Alan
    Western Australia
    Default dizzy oil leakin.. cont
    posted this thread before the site went thru the portal and it didnt come out the otherside (i guess with everythin else!) and i lost all the info in it
    Pretty much got an oil leak out of the dizzy - i think the seals busted..
    A few people offered their advice about what to look out for when fixing it and it was gladly appreciated.
    Couple of things i wanted to know were: 1) what main things to look out for and do when going in to operate? and 2) where do i buy replacement seals/rings from?
    cheers again for the help!
    al
    Senior Member n00bvak's Avatar
    Novak
    SOR
    repco should have seals or go to toyota for fully hecktic manufacture spares prices
    --- All your base are belong to Phil Bradshaw!!! ---
    <<< blog >>> build thread<<<
    Senior Member doony's Avatar
    Dan
    i got my dizzy o ring for under $4 from toyota inner and outer. had it in stock and ready to go.
    Or driving in a wolf pack.
    Alan
    Western Australia
    yep that was the thread doony.. cheers!
    well its all done.. took me all day but hey learned a few new things
    odin auto's ended up having the right inner u-seal (part no. 400704N) and i 'pandered' and just got an o-ring from toyota- but found out later odin had one anyway.. (both $7.20)
    oil leakin out bottom of dizzy
    sorry no pics.. but both ring and u-seal were hard an knackered!
    probably most tricky part was getting the dizzy gear off, had to drill out the pin in one end and punch it out (cos its mushroomed out on both sides) - was told if u try and punch it out without drilling you risk making a mess of the shaft and gear.. then replaced everything an yeh just stuck a roll pin in with abit of loctite .. sweet as!
    marking everything helps big time
    Dan
    good to hear mate!
    learning is invaluable.
    性交を愛する
    Good to hear it's fixed.
    Senior Member vivioman's Avatar
    Vernon
    Aveley
    I had the same problem as well...leaky distributor, but the O-ring was fine when the distributor was removed...turns out that the inner seal was dry and brittle, so probably the sealing effect was compromised.
    I got the part from Statewide Bearings (very effficient guys) for ard $5. This is the inner seal (also known as TC10/20/7 - I got to know this from another forum, didn't see this post previously):
  1. 4age dizzy oil ring seals
    By jmae86 in forum Technical - Questions
    Last Post: 18th August 2012, 11:09 AM
  2. WTB: 4agze dizzy or 4age bigport dizzy
    By Sleeper86 in forum Cars or Parts Wanted
    Last Post: 19th July 2012, 07:25 PM
  3. New Trueno (cont from old forum)
    By pj_black Knight in forum AE86 Owners Forums
    Last Post: 5th May 2009, 02:29 PM
  4. WTB: MR2 Dizzy or AE82 Dizzy
    By ae86driftstyle in forum Cars or Parts Wanted
    Last Post: 19th June 2007, 01:45 PM
  5. Dizzy oil leak
    By wide s13 in forum Technical - Questions
    Last Post: 26th May 2006, 10:02 AM
