Results 1 to 6 of 6
Thread: na cams in gze
    c
    Default na cams in gze
    So i dont think my 86 is going to sell.so..
    Would there be any gains on putting na cams in a ze? Is there even any differance? Just got some sitting here
    Reeece
    Casula
    they are ok for backyard performance.. i gainned 5-7kw threw rev range with same boost..
    This is with a snail but.....
    Gone
    Joel
    Picton
    worth the 5-7 KW? its up 2 u but i wouldnt think so.
  • #4
    Reeece
    Casula
    Default yer
    its worth it when its threw the rev range mate .. turbo's need more air to perform.. So i would recommened it if your wanting mid range power for close to zero $$$$ Most n/a drivers would spend up to 2 g for extra 5kw BTW
  • #5
    Moderator Sam-Q's Avatar
    Endeavour Hills
    the ZE cams are the same as non ZE cams. Bigport cams in a smallport works though
  • #6
    Mt Macedon
    ^^^ I have the same view.
    Easiest way to tell is to measure the lift of your current cams. If they are 7.1mm lift then you can get some benefits from fitting the 7.56mm jobs.
  • Similar Threads
    1. Replies: 5
      Last Post: 13th September 2012, 08:13 PM
    2. BP cams into ae101 GZE
      By trikzlane in forum Technical - Questions
      Last Post: 13th April 2011, 08:22 AM
    3. cams for na stock 4age
      By pen15 in forum Technical - Questions
      Last Post: 6th March 2009, 01:04 PM
    4. na na na na na na na na na BATLEB!
      By snake in forum Offtopic Discussions
      Last Post: 8th November 2007, 10:05 PM
