Results 1 to 3 of 3
Thread: Leaking Diff
    Dave
    The Ghetto
    Default Leaking Diff
    hey guys my diff centre or housing is starting to leak oil, i was just wondering what is the best way to fix this problem? I was thinking about taking it to the mechanics but was afraid i'd get flamed for having a welded diff. Also what would be the cause of the leak. Broken seal?
    Thanks
    Veteran johl's Avatar
    Johl
    yeh most probably. just rip the diff out and take it to someone if you want to, or pull it apart yourself. not too hard. cant really mess anything up if you've never done it before just remember to use a sealer when putting the nose of it back on
    Senior Member kaibeecee's Avatar
    Pete
    it's the standard paper gasket thats the problem, if the diff seal has ever been broken, you have to scrape it ALL off with a razor blade and put a new gasket on.
    i had the same issue, even with alot of gasket sealant, just had to make sure all the paper shit was off.
  1. diff leaking
    By johl in forum Technical - Questions
    Last Post: 28th February 2009, 09:25 AM
  2. leaking Petrol
    By Mr Fujiwara in forum Technical - Questions
    Last Post: 1st October 2008, 09:24 PM
  3. leaking Inlet valves
    By stuartgze in forum Technical - Questions
    Last Post: 1st November 2007, 08:20 PM
  4. gearbox leaking from the rear
    By deanoo in forum Technical - Questions
    Last Post: 27th September 2007, 11:04 PM
  5. clutch fluid leaking
    Last Post: 8th April 2007, 04:10 AM
