Page 1 of 22 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 219
Thread: Richies 86
    Senior Member DRFTR86's Avatar
    Richard
    South Oakleigh
    Default Drftr86 ca18det ae86
    so another year, another revamp for my 86, this is the build list for 2009, enjoy, stay tuned
    ENGINE
    CA18DET
    KKR 330
    Highmount stainless steel manifold
    444cc GTR Injectors
    Z32 AFM
    Cosmetic Metal Head Gasket
    ARP Head Studs
    Hybrid Front Mount Intercooler
    Apexi Intake
    Nistune ECU Chip
    Carter Lifter Pump
    Bosch 070 Fuel Pump
    Surge Tank
    206RWKW @ 16psi Tuned by Dr. Drift
    DRIVETRAIN
    OS Giken Lightened Flywheel
    OS Giken Carbon Clutch
    Borg Warner R31 Differential, Mount swapped and minispooled w/4.11:1
    Custom 1 Piece 3 Inch Tailshaft
    SUSPENSION
    KYB AGX 8 Way Adjustable Shock Absorbers
    Techno Toy Tuning Coilover Weld on Kit
    Techno Toy Tuning Cambertops
    Eibach 8 Kg/mm Front Springs
    Techno Toy Tuning Negative Roll Centre Adjusters
    Techno Toy Tuning Adjustable Castor Rods
    AJPS Lock Spacer
    KYB Sierra Rear Shock Absorbers
    AJPS 6 Kg/mm Rear Springs (have to get)
    Rose Jointed Trailing arms (have to get)
    Whiteline Adjustable Panhard Rod
    Alignment Specifications
    -3.5 Camber
    +3.0 Castor
    +2mm Total Toe
    BRAKING
    AJPS Caliper Adaptors
    Mazda FC RX7 4 Piston Calipers
    Honda Civic EG Front Disc Rotors
    Holden Commodore VR Rear Calipers (pedal brake)
    Holden Commodore VR Rear Calipers (hydraulic handbrake)
    Nissan Skyline R32 Non ABS Master Cylinder
    INTERIOR
    Reclinable Bucket Seat
    Bolt in Half Cage
    GKTECH Drift Steering Wheel
    ISC Hydraulic Handbrake
    VDO 5” Tachometer
    Custom cluster, consisting on 7 gauges + Blitz Power Meter
    Fully Stripped and Gutted, Re Carpeted
    EXTERIOR
    Kouki Front Bar (have to get)
    JDM Foglights (have to get)
    Kouki Rear Bar (have to get)
    FRP Bonnet (have to get)
    Dmax D1 Style Front Fenders (have to get)
    Whiteline Taillights (have to get)
    WHEELS
    2 X 15 x 8 – 4 Performance Superlights
    2 X 15 x 7 +- 0 Meshies
    4 x 14 x 6.5 + 20 Meshies
    Veteran Wally's Avatar
    looks tough as nails.
    what injectors you running?
    4AGE 16V
    Senior Member stylz's Avatar
    Art
    Melb
    what kinda cams do you have to pull 90kws?
    I think it says WADE 800A cams!.....dope ride by the way! I like the setup.
    Back 2wrk I go. :/
    Wade 800A Cams are:
    Profile No :
    800a
    Lobe Lift :
    Ex .360 In .360
    Timing AdOpen Close :
    80-48 50-78
    Duration @.050 :
    Ex 253 In 253
    Valve Clr :
    010
    Valve Lift :
    0.350
    Lobe Sep :
    105
    Rocker Ratio 1.6 : Competition mid to top end
    needs springs
    Those would dimensions would be in inches.
    Valve Lift: 8.89mm
    Lobe Lift (Ex 9.144mm In 9.144mm)
    Vlave Clearance: 2.54mm
    4AGE 16V
    Art
    Melb
    Quote Originally Posted by JDMJNKY View Post
    Back 2wrk I go. :/
    the specs of the cams.. relax there buddy
    Art
    Melb
    Quote Originally Posted by Wally View Post
    Wade 800A Cams are:
    Profile No :
    800a
    Lobe Lift :
    Ex .360 In .360
    80-48 50-78
    Duration @.050 :
    Ex 253 In 253
    Valve Clr :
    010
    Valve Lift :
    0.350
    Lobe Sep :
    105
    needs springs
    Valve Lift: 8.89mm
    awesome, thanks for that mate. i expected the duration to be alot higher for 90rwkw's? or is the dyno fairly number happy?
    just curious as thats close to what im building the next engine to, just with slightly more aggressive cams
    Quote Originally Posted by stylz View Post
    didn't mean to come off all loco, I guess it was just the formulation of the question....No harm, no fowl.
    I dig your MC sock,
    Richard
    South Oakleigh
    cams put out a big kick at about 4500 rpm, sound like a vtec flat out cos of the quadz
  1. Richies Ae71 Thrasher..
    By hilux05 in forum KE70 / AE71 Owners Forums
    Last Post: 1st September 2012, 11:38 AM
  2. 16valve 4age, 86 sideskirts, 86 adjustable panhard rod :)
    By timpy in forum Car Parts For Sale
    Last Post: 5th October 2010, 08:23 PM
  3. Replies: 29
    Last Post: 16th July 2007, 01:22 PM
  4. 32/36 weber, 86 doors, 86 hatch
    By Craig_AE86 in forum Car Parts For Sale
    Last Post: 17th May 2007, 01:56 PM
