Results 1 to 10 of 13
Thread: rear spring rubber caps do you run them
    sa
    victor harbor
    Default rear spring rubber caps do you run them
    hey guys i was wondering if you are supposed to run the standard rubber spring caps with stiffened and lowered rear springs.
    All I know is that it makes allot of noise with out them.
    But will it effect the rear spring rate if I put them on. Or is the cushioning effect of the rubber allowed for?
    Ferny Grove
    pretty much just stops diff noise transfeering to the body via the steel on steel spring to body contact.
    definately noisier without them.
    mine have always been pretty rooted (split or torn apart) so i never bothered running them
    sa
    victor harbor
    yer but are they going to effect spring rates much?
    Trev
    Queensland
    Redbank Plains
    It is a dampener, It will make your car lower if you take them out but id rather run them.
    Are these the 1/2 - 3/4" block or the really small rubber cap thats about 3mm thick?
    Senior Member shichi~'s Avatar
    Ethan
    North Suburbs
    u wont even notice the spring rate change if there even is any
    性交を愛する
    I run them. But being ~25 years old they are somewhat shagged.
    West
    They serve a purpose and are meant to be there. Thats good enough for me.
    Nothing wrong with a little spring to diff traction.
    Veteran johl's Avatar
    Johl
    i run one. never had the second but for some reason i always put this one back in
    I took them out when I put new springs in the other week.. was way too noisy so next time I had it up on stands put the thicker one back on.
    It made it sit higher which is gay, but Im glad I put them back in as I could hear the springs moving around before.
    A
    Parky
    If toyota put them there i say leave them there
  1. Replies: 1
    Last Post: 1st August 2011, 04:36 PM
  2. Replies: 2
    Last Post: 12th July 2011, 12:02 AM
  3. buying rear spring rubber attachments.
    By Ade_Mc in forum General Topics (No Technical Questions)
    Last Post: 9th December 2010, 11:01 AM
  4. Rear spring Rubber Seat thingys
    By sly1300 in forum Cars or Parts Wanted
    Last Post: 10th April 2009, 11:20 PM
  5. Rear Window Rubber
    By wide s13 in forum General Topics (No Technical Questions)
    Last Post: 13th December 2005, 05:31 PM
