Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: V6 swaps?
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    Default V6 swaps?
    now we have seen 1uz swaps in ae86's but that would never be street legal.
    would a v6 be able to get street registered? is it able to be done as easily as say a v8 swap?
    thoughts?
    i like the sound of a 2GR-FSE, 232kw @ 6400rpm out of a lexus gs350.
    http://en.wikipedia.org/wiki/Toyota_GR_engine
    Julian
    Northern suburbs
    it would entirely depend on what the state laws are for the maximum Litre engine in the chassie of a particular weight.
    From memory in VIC the maximum legal size you can put into a sprinter is a 2.7L NA engine
    Elite rthy's Avatar
    Leo
    Tulla
    someone in vic has a v8 4.0l 1uz in an ae86
    there also also some ae86's with the 1gg 2.0 stright 6
    engineered or streetlegal?
    also
    older ta/ra celicas tend to have v8'smotors too
    Dan/Rio
    Randwick
    engineered and street legal is what im after
    Gunner
    hink there is a calculation on the RTA site that will help you figure it out. Don't have clue if its still there
    c
    Iv seen a ke70 with a vn v6 in it. was registered, in qld tho
    User fantapants's Avatar
    Pat
    in queensland i think the limit is 3.7l in the hachi.... the 1uz was just out of it from memory, but the vq35 was ok when i was looking into it - not sure on the necessities for engineering though
    06/07/2011
    Veteran slydar's Avatar
    Dimitri
    http://www.infrastructure.gov.au/roa.../vsb_ncop.aspx
    thats a pretty decent guide to whats legal and whats not, the intent is for that to become a nation wide code eventually.
    the code lists for an NA engine, original weight in kg of vehicle x 4 for vehicles between 800 and 1100 kg. so youre allowed over 3.6 liters.
    the number of cylinder is irrelevant. as long as its below the max capacity and can be fitted without the need for illegal modifications. v6 would be easy, but most of the affordable toyota ones are a little difficult to mount in rwd cars.
    Senior Member gaz20v's Avatar
    Gareth
    Lismore
    ive always been keen on a 3vz fe from a later model camry, 3L and around 150kw stock. would make for good torque and apparently not too hard to squeeze a little more power out.
    unfortunatly in nsw the capacity X weight rule for up to 1100kg is weight X 3
    bring on the nation wide ruling!!
    Dan/Rio
    Randwick
    yeah nationwide 1100 x3......... they always go with the harshest rules when they go nationwide
    this is interesting to think about. maybe next project ill attempt something
  1. KE30 V6
    By koolstik in forum Cars for Sale (Toyota Only)
    Last Post: 12th June 2008, 02:56 PM
  2. Replies: 3
    Last Post: 2nd March 2008, 02:31 PM
  3. commo v6 into ke70
    By Nic19 in forum Technical - Questions
    Last Post: 12th November 2007, 07:25 PM
