Results 1 to 10 of 11
Thread: 1zz coilpack wiring diagram and Haltech settings
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    Default 1zz coilpack wiring diagram and Haltech settings
    Hey all,
    trying to wire in some 1zz coils to my haltech and i need a pinout for them. I also need the coil settings so i can set them up on the haltech software, i'm hoping someone will know if they are a rising or falling edge signal, and if they have a smart or dumb ignitor module.
    I'm also using a Gze CAS and i need to know if that has a rising or falling edge signal.
    any diagrams/advice would be great
    Andy
    Mt Macedon
    the 1zz coil wiring has been talked about on Toymods before. Search for a thread by "shelldrake". May also have the ignitor info in there.
    4AGZE CAS is falling edge if memory serves me correctly.
    Anthony
    Theyre smart so just run a dwell of 3 ms. cant hurt them.
    As for pins. looking into the coil pack or at the back of the plug pin 1 (LHS) is ground, next pin is trigger to go to haltech, pin 3 is IGF, just leave disconnected and pin 4 is ignition 12V.
  • #4
    anyone got some of these suckers they dnt need or know somewhere that does?? need some
  • #5
    8ball
    The wreckers.
  • #6
    Andy
    Adelaide Hills
    you guys are champions... that's exactly what i needed.
    i'm assuming the wire that goes to the haltech is the trigger wire for the coil?
    Andy
  • #7
    Andy
    Adelaide Hills
    new problem,
    coils fire when you have the plugs out of the engine, but when the plugs are in the head there is no spark, untill you stop cranking the engine and you get one spark as the motor stops turning over.
    had this issue before using 1jz coils but i couldn't solve it
    Andy
  • #8
    Andy
    Adelaide Hills
    anyone?
    Andy
  • #9
    Mason
    Salisbury East
    Hey mate
    You must have the trig terminal & ground terminals and wires from ecu mixed up.
    You also need an aftermarket ignition module or 2 to run the coils as i don't
    think the standard one is compatible with the Haltech.
    Try and call Haltech tech line they should be able to help you.
  • #10
    Mason
    Salisbury East
    Hey mate
  • Page 1 of 2 1 2 LastLast
    1. GA70 wiring Diagram?
      By Hazzard in forum General Topics (No Technical Questions)
      Last Post: 8th November 2010, 12:40 AM
    2. 4AGZE Wiring diagram
      By Wally332 in forum Technical - Questions
      Last Post: 19th April 2010, 01:07 AM
    3. Complete wiring diagram
      By stylz in forum Technical - Questions
      Last Post: 5th June 2009, 02:24 PM
    4. ke70 wiring diagram
      By bigm in forum Technical - Questions
      Last Post: 24th December 2008, 08:44 PM
    5. need wiring diagram for mtx-8
      By shaun2 in forum Technical - Questions
      Last Post: 15th July 2007, 01:31 AM
