Results 1 to 10 of 10
Thread: carnage
    Veteran johl's Avatar
    Johl
    Default carnage
    so what did u break/smash/damage today?
    doesnt include smashing box.....
    i'l start. i snapped another axle today. just took off at a set of lights real slow and nana spec and heard a huge clunk. clunks are normal in my car with a rose jointed rear end and bad backlash but this was massive.
    so yeh tow home, bought 2 axles (thanks dimitri!), new seals and bearings, oil, and while i was at it i serviced car with gearbox oil and engine oil and filter. all up cost me around $400.
    just hope i havnt warped my lsd as i had to drive for a little bit till i flagged down a tow truck.
    性交を愛する
    My Sump got fucked up before? And i have half a sump bolt as well?
    Senior Member stylz's Avatar
    Art
    Melb
    tapped a gutter last night, got slight toe out on one side, hoping nothings bent
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    drilled my foot pulling out my W55 by myself just before... was trying to hold the bellhousing end up with leg and bench press the other end.... meh, g/box and engine are out now...
    BENT MECHANIX - Garage 20:
    Scammer, DO NOT BUY FROM ME!
    lol once while trying to undo the top nuts on my rear shocks i was putting all my force into it and when they finaly let go my nose smashed into the edge of the boot resulting in blood everywhere.....i lol'd later
    Veteran svenmate's Avatar
    Svenbot
    East
    i broke a 4kc... which i thought was impossible :p
    AE71 Build Thread
    Senior Member Roo.'s Avatar
    Andrew
    Gold Coast
    blew the diff in my car, gears when though the casing and bellhouse
    wow good effort!!!!
    Senior Member Toy-Yoda's Avatar
    ^^^ That is extremely impressive.........
    The hell were you doing to cause that?
    Josh Curwen, 26/02/1987-26/10/2008, the world is a lesser place without you, you will be missed little Fox, game on..........
    Quote Originally Posted by 7shades
    If traction and articulation won't get you there, speed and stupidity will
    Member of the Leaf Sprung Axle Trampers Club
    Click me for epic jump video I is used the force.......
    性交を愛する
    My clutch... I don't have one..
    2nd gear 4000rpm no wheel spinnage.. OHHHH YEAAAH. Smelt so good.
  1. D1 Carnage
    By Eircamae86 in forum Offtopic Discussions
    Last Post: 1st April 2009, 09:31 AM
