Results 1 to 8 of 8
Thread: Retuning stock ecus
    c
    Default Retuning stock ecus
    Who can do this in brisbane? How much does it usually cost?
    Veteran slydar's Avatar
    Dimitri
    cant be done on a toyota like a nissan.
    the closest thing to "retuning ecu's" is sams razorback.
    if you have a fairly mild set up, there may be other things you can do to make it run better, other than actually modifying the fuel and ignition maps inside the computer.
    c
    Quote Originally Posted by slydar View Post
    Was thinking of wide s13 7age. what sort of things would need to been done for this?
    for the specs of the 7age-
    7afe bottom
    trd .8gasket
    skimmed smallport ported head
    hks cams if he going to use these 272 in 280 ex 8.1lift
    bigport injecters
    and you would proly use a bigport ecu i found out as i got told i have a bigport rwd manifold so not sure if it would make a differnce?
    i have std bigport cams that can go in this.
    Dimitri
    the cams are too big.
    you could try a cheap 2nd hand apexi AFC.
    Gone
    Joel
    Picton
    biggest cam u can run with stock ECU is 264'
    c
    I was just thinking of it with bigport cams
    im putting the bigport cams in this and trying to borrow a std bigport ecu so ill let you how it runs with std ecu.
  1. 4age Loom and ECUs
    By Nikkojoe in forum Car Parts For Sale
    Last Post: 14th July 2009, 08:19 PM
  2. Tuning Freedom ECUs??
    By 4A-GE Power in forum Technical - Questions
    Last Post: 4th June 2009, 11:06 AM
  3. ECUs and Looms
    By foxtail in forum Car Parts For Sale
    Last Post: 10th July 2008, 10:43 PM
  4. 20v ecus
    By Rich_86 in forum Technical - Questions
    Last Post: 18th January 2008, 06:55 PM
  5. Aftermarket ECUs ?
    By Jonny Rochester in forum Technical - Questions
    Last Post: 29th December 2007, 06:39 PM
