Results 1 to 4 of 4
Thread: 4AC-4AGE Questions
    Junior Member mattty's Avatar
    Default 4AC-4AGE Questions
    Hey im pretty new to all of this and have just purchased a ae86 shell off my mate. It was a 4ac carby set up but im now putting a 4age motor into it. i have the conversion under control but im a little worried on how i will go with a roadworthy cert in victoria. will i need engineers cert?
    Will i need a 4age mod plate?
    any help would be much appreciated!
    thanks
    Senior Member KE70GT's Avatar
    Gavin
    kilmore
    I put a 4ac into my ke70 which originally had a 4kc later on I got defected for worn tyres so I had to get a rwc the guy gave my the rwc but he told me that I had to let vic roads know that there was a different engine, I never did that and I got my defect cleared vic roads still don't know lol
    It all depends on how legal you want it I don't know how you will go getting a 4ag through vic roads
    Senior Member adam's Avatar
    Adam
    You technically do need an engineers certificate for the 4AGE motor in your originally 4AC powered 86, but you'll be able to change the engine number at VicRoads easy. Both engine blocks start with '4A' then some other random numbers.
    The people who check your motor at VicRoads wouldn't know the difference. When changing your engine number, they just look for the engine number on the block and see if it matches the forms you have to fill out.
    Previous ride: 4AGE powered KE70.
    Current: JZX100 Chaser and '73 Datsun 240z.
    http://twofortyzee.wordpress.com
  • #4
    Senior Member shakes's Avatar
    Simon
    Vic
    Melb
    just out of curiousity. has anyone here been in an accident and had them knock back insurance due to illegal mod's?
    Sure you'll have the right engine number on your rego, but that basicaly means your run of the mill cop wont hassle you. If someone knows what they are doing they will still ask for engineer papers...
  • Similar Threads
    1. 4AGE questions
      By Sprinter Freak in forum Technical - Questions
      Last Post: 12th May 2011, 02:27 PM
    2. 4ac and diff questions.
      By Skremn in forum Technical - Questions
      Last Post: 7th August 2009, 02:22 AM
    3. 4AGE questions
      By PHAT86 in forum Technical - Questions
      Last Post: 3rd July 2008, 03:33 PM
    4. 4AC 4AFC questions?
      By dog89 in forum Technical - Questions
      Last Post: 28th April 2006, 01:33 AM
