Maybe 185 50?
Looking good though
I see guard work in you future,and nothing mild about it!!
Will look hot as dumped on its rails with some fat arches!
Look forward to seeing it!
43ger
Performance
SINCE 2008
Maybe 185 50?
Looking good though
yer rear will be a bit of a headache, this shit is so sick though haha love it!
I was looking at the shape of ma61 supra flares in comparison to the st141 arches......kinda similar...might be worth looking at maybe?
43ger
Performance
SINCE 2008
Yeah I think I might for the fronts when I can afford it. The lack of stretch compared to the back is already getting to me. Maybe stick with 55 profile though, 50 may look too small on a bigger car.
I found out last night that an RA60 diff is 10mm shorter each side, as well as a straight swap, so I'm going to use the diff from the same car I took the exhaust from before, which will make them tuck alot easier with less gaurd work
Not a bad idea, but not really a fan of bolt on flares at all, MA61s being one of my least favourites, hehe
Thanks! Are you sending my stuff through auspost or courier? I only gave you a P.O. box and I've just realised I don't think couriers will deliver to those, so let me know if you need a home adress man.
yer good idea, 10mm will make it workable for sure!
Just use some bigger 205's on the rear.
Looking good.
This is full of win.
Have got some shit done, RA60 T series diff is in (higher final drive, 3.89 vs 3.42, and 10mm narrower each side).
Managed to crack my front lip some more by hitting the bushes next to where I park, zip tied that up sorta neatly. Somehow managed to put a big bow on the drivers side front gaurd, guessing from the wheel hitting the gaurd, it does that sometimes, thanks body roll. Also bought a black grill, only to realise it was way too wide (different headlights), so I just left it off for now.
Oh and note theres a badge on the bonnet now, was missing when I bought the car. The rear wheels sit pretty much perfect now, won't need much more then a roll once it's lower.
Fingers crossed suspension arrives this week.
The one that was in it, ended up being the right length, but only 2 holes lined up. Ran out of time to drill those so is just running on 2 bolts atm. The recessed/raised bits don't mate properly either, but meh, it's kinda dodgy, might fix it later, might not.
