Raybrig Headlenses:
Hi guys,
I've had my Trueno since May 2007 now, and yeah been driving it as a daily since then. Probably what has cause my stuffed back as the thing rides as stiff as a boner in a strip club.
Anyways here is some details:
Manufacture Details:
Make: Toyota
Model: AE86 Sprinter Trueno GT-APEX
Year of Manufacture: December 1984
Plant of Manufacture: Tahara Plant located in Aichi, Japan.
Body: Hatch
Colour: Red / Black Panda Scheme
Engine (currently being installed):
4AGE 16V
Bigport Head
Smallport Bottom End (Oil Squirters)
HKS 264 8.1mm Cams
T3 Adjustable Cam Gears
T3 20V/16V Adapter
20V Silvertop Quads
T3 Silver Velocity Stacks
External Fuel Pressure Regulator with Gauge
4AGZE Injectors
Gates Timing belt
Relocated Oil Cooler + Oil Filter
Head has been polished
Block has been decked and honed
Flywheel and crank been machined
Full engine rebuild
ECU:
Microtech LT10S
Other Bits:
Bosch 040 fuel pump
RB20 fuel filter
Oil catch can
Drivetrain:
New Exedy button clutch, pressure plate and throwout bearing
JDM T50 with TRD Gearset
TRD 2-Way LSD
15" Longchamps (Offset Unknown)
Toyo Proxes 4 Tires
Miscellaneous:
Front Strut Brace
Rear Strut Brace
Adjustable Cusco Camber Tops
TRD Green 8-way Adjustable Rear Shocks (Set at 4)
Unknown front shocks
TRD Ignition Leads
TRD Oil Cap
Nardi Steering Wheel
Other:
Foggies
Raybrig Headlight Lenses
Redline Taillights
Standard Digital Dash
AJPS Dashmat
Rear Hatch replaced
Brand new Genuine Toyota sunroof and weatherstrip ready to go
Replaced rear seats - now no rips
Reconditioned Radiator x 2
Toyota Emergency Flare :o
Work to be done:
New Exhaust (TRD Copy 4-1 Kaizen Garage Extractors + 2.25" exhaust)- ASAP
Engine Rewire / ECU Install / Dyno Tuned - ASAP
Coilovers - March
Reclinable Bucket Seats - March
4AGE 16V
Raybrig Headlenses:
4AGE 16V
What a beatiful 16v!!!!!
Yummmay quad kitted 4age, Lower you car some more man and get some stretch happnin yooow
thanks guys... long way to go though!
hahah yer that is on the agenda. Will be looking at coilovers all round in the new year sometime!
Is pretty low at the back, can just fit my fingers between the tyre and guard.
4AGE 16V
Hopefully picking the car up tomorrow if everything goes well!
4AGE 16V
sweet man, cant wait till its all good
you're telling me! I should have had it back 2 week ago, but I was fucked around with an exhaust shop which delayed me.
If i get it back today, its exhaust then rewire of engine bay + Microtech and tune!
Then she should be sweet!
4AGE 16V
