Results 1 to 6 of 6
Thread: brake booster - removing, smaller one, other ideas
    Senior Member h1_roll4's Avatar
    Josh
    C raigie
    Default brake booster - removing, smaller one, other ideas
    hey all.
    im having a problem fitting everything in my engine bay.
    i have a twin carb 4age in ke70.
    the manifold and carbs stick to far out and i cant fit a filter or anything between the carbs and the brake booster.
    is there a way i can remove the booster, or is there a smaller one the will fit, or does anyone have a better idea.
    i dont want to spend stoopid amounts of money.
    yeah, any help.
    only pic i have atm
    edit: wrong section, mods please move
    Last edited by h1_roll4; 11th January 2009 at 02:16 AM. Reason: wrong section, mods please move
    Senior Member hilux05's Avatar
    Rich
    Sunshine Coast
    daymn.. what mani are you using?? it seems to stick out hella far..do you have a bigport/small port adapter on there too??
    apart from an in cabin mc maybe mount just a mc on the fire wall then get a remote mounted vh40/44 booster out of an old holden..shouldnt be too much.. i have to do this on me ke25 now too..
    Josh
    C raigie
    Quote Originally Posted by hilux05 View Post
    its a hks manifold, and its a smallport with the adapter.
    cheers i'll look into that
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    try a Silvia s13 brake booster and master lots thinner looks like it should all fit up with s13 by memory it should all bolt up a friend has 1 in his ke70 for sr20 to fit with room lol
    the dyno pull to 300rwkw
    West
    KE30s and 55s had an interchangeable smaller diameter booster, if you can find the one with the horizontal studs for the master like the ke70/ae71 has. Been researching this myself. You can always use a remote booster, I think some Hondas had good factory remote boosters.
    Jonathan
    Check that you have a AE71 crossmember, as I suspect the KE70 crossmember puts the motor in the wrong position. (Not sure).
    Either way, don't be scared to modify the engine mounts to move the motor over for more clearance.
  1. BRake Lines - Brake Booster One-Way valve
    By bigm in forum Cars or Parts Wanted
    Last Post: 29th January 2010, 06:56 AM
  2. Brake boosters smaller options?
    By NIZLAH in forum Technical - Questions
    Last Post: 7th February 2009, 09:23 AM
  3. TA23 Brake upgrade- any ideas??
    By hachirokuGTV in forum Technical - Questions
    Last Post: 7th May 2008, 07:14 PM
  4. brake booster or no booster?
    By slippry in forum Technical - Questions
    Last Post: 29th April 2008, 11:41 AM
  5. brake booster
    By starni_boy in forum Technical - Questions
    Last Post: 11th February 2007, 05:52 PM
