I've got a camry one in there not sure what model it is from but it lines up ok and has twin thermos.
The two probs were the battery had to be swung roung 45 degrees and the top hose didn't line up so I had an alloy connector made up seems to keep things cool even when it's a really hot day.
I'm assuming the fact that the top and bottom hoses are on different sides helps the coolant has to go through the whole rad where as on the standard rad the pipes are both on the same side.
Leigh
