Results 1 to 10 of 13
Thread: Brake booster!!!!
    Ade
    SYD, Inner west
    Default Brake booster!!!!
    hi,
    i need need to replace my MC,
    bought a JDM one along with a JDM booster.
    i have managed to undo 3 of the bolts holding the booster on, but can't
    manage to remove the 4th which is up in the top left corner.
    do i need to remove the dash!? because i just put that back in and couldn't
    be rooted taking it back out!!!!
    any advice would be appreciated.
    also what should i use to loosen the brake lines off the MC?
    as they are on as tight as a frog's water tight asshole.
    eshay ad-lays
    ade mc
    c
    Quote Originally Posted by Ade_Mc View Post
    hi,
    eshay ad-lays
    ade mc
    I used a wobbley joint connector on a ratchet with extention arms(dont know its real name)
    Vice grip to loosen the nuts on the mc
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    pour boiled water over the brake lines before trying to undo them if they are super tight.... works a treat...
    BENT MECHANIX - Garage 20:
    Jonathan
    The proper tool is a 10mm pipe spanner for the brake lines, but even they sometimes open up and slip around. This is why you have to hit the spanner, and sort of suprise the nut. Hopefully you will hear a crack and it comes loose. If you just lean on it gently and gradualy use all your force, you will probably round it off.
    Senior Member Stain's Avatar
    Derek
    Far North
    i used to round brake line nuts all the time until i got a good qual 10mm spanner. never happened since
    Senior Member Simon-KE70's Avatar
    Simon
    yeah quality tools go a long way.
    so does soaking the stuff in CRC or WD40 a few hours before you start
    Ade
    SYD, Inner west
    sweet thanks everyone, i will be heading up there to repco to get some decent spanners.
    should be sorted tomorrow.
    ade mc
    Well Im up to this stage as well and I cant manage to remove the booster at all.
    Do I have to come from underneath the dash? If so how much of it needs to be removed?
    Timmy D
    North
    all i used to undo the booster was a spanner? no you do not need to remove your dash. Make your life a hell of allot easier and spend 10 min to remove your seat, that way you can lie down and take your time. there is 4 nuts to remove, also a pin from the top of the brake pedal which just needs some long nose pliers. also a small tourch helps you to see everything that is going on. there is nothing worse than crap tools!! good ones make working on your car far more enjoyable
    JJ
    Ade
    SYD, Inner west
    well put tim.
    an extender piece helps heaps too!
    the bending extender piece made it a breeze.
  1. BRake Lines - Brake Booster One-Way valve
    By bigm in forum Cars or Parts Wanted
    Last Post: 29th January 2010, 06:56 AM
  2. brake booster
    By Mr Fujiwara in forum Technical - Questions
    Last Post: 17th September 2008, 08:20 PM
  3. brake booster or no booster?
    By slippry in forum Technical - Questions
    Last Post: 29th April 2008, 11:41 AM
  4. brake booster
    By starni_boy in forum Technical - Questions
    Last Post: 11th February 2007, 05:52 PM
  5. brake booster
    By mikkas in forum Technical - Questions
    Last Post: 13th September 2005, 09:15 PM
