Results 1 to 10 of 10
Thread: changing from steer box to rack and pinion in t18
    c
    Default changing from steer box to rack and pinion in t18
    Can you change the steering box to a rack and pinion without changing the cross member?
    Im of the opinion you cant but just want to clarify
    Jonathan
    You actualy need a custom crossmember. But from memory I think the AE71 crossmember will do the job good enough. I havn't done it.
    But beware that there is lots of stuff to swap over to do the job right, including some cutting of the firewall.
    You would need to swap over the whole steering colum and maybe even the pedals also, and modify the firewall a bit.
    Senior Member Fozz's Avatar
    Nathan
    Gold Coast
    yes but u need to cut the rack mounts off a a or k series mount and reweld them on the t series mount
    c
    so if i got a full steering setup from a ke70 at the wreckers it would do with a few mods
    Jonathan
    yes
    But be warned that you need the whole steering colum, and maybe the pedals also. And some cutting of the firewall, and maybe some drilling etc.
    And check the clearance between the rack and the sump of the 3T-C.
    You can do anything with these tools (and you will need them):
    strong bench
    strong metalwork bench vice
    big hammer
    hacksaw
    welder
    drills
    files
    cold chisel
    tin snips
    Veteran stahlz_ae86's Avatar
    Paul
    PM JHS, He's done the swap.
    Davey & Riki-lee
    South Australia
    Seaford SA
    that was with a a cross member and he put the 4age in.^^
    Our introduction - Click here
    Skid Kid
    i have also done the conversion with a 3tc....
    you do not need a custom crossmember at all...
    what you will need..
    KE70 Crossmember
    KE70 Steering Coloumn
    KE70 Steering Rack
    T18 Rubber Engine Mounts
    TA23 Steel Engine Mounts
    T18 Steering Coloumn Shroud...where it bolts to the firewall...
    bolt it all together...
    no need for any other parts...
    c
    Quote Originally Posted by Skid Kid View Post
    KE70 Crossmember
    KE70 Steering Rack
    Thanks bud. very helpful
    c
    ta23 engine mounts are next to impossible to find. Might just go 4age
  1. Steer rack rebuild?
    By starni_boy in forum Sydney & NSW Events and Discussion
    Last Post: 24th October 2010, 09:20 PM
  2. rack and pinion
    By d1doony in forum Technical - Questions
    Last Post: 29th July 2008, 05:54 PM
  3. RACK & PINION or R/B?
    By Yellow Keto. in forum Technical - Questions
    Last Post: 7th December 2007, 03:23 AM
  4. quick rack with power steer?
    By 350hp4agte in forum Technical - Questions
    Last Post: 29th November 2007, 02:58 PM
  5. crown wheel and pinion changing??
    By ae86dave in forum Technical - Questions
    Last Post: 19th May 2006, 07:35 PM
