Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 38
Thread: How To: Flare Guards
  1. #11
    Veteran Konakid's Avatar
    Henry
    Eastern
    good thread!
  2. #12
    Nic
    Mt Evelyn
    wat do you guys do about getting the front part of the flare to stop hitting the wheel when you turn!! do you flare it out like mysh*tboxKE70 or just trim down the guard?
  3. #13
    Senior Member GOODY's Avatar
    Logan
    Adjust castor or cut it, I adjusted mine to make it clear but I think that gives your front end less grip??
  4. #14
    Nic
    Mt Evelyn
    yeh i wanted to flare it. think it would be more appropriate on a street car. its on slant front guard so i can change it wen i go flat front if i want
  5. #15
    Henry
    Eastern
    just trim it down.
  6. #16
    Nic
    Mt Evelyn
    any tricks on how to get a nice line to cut to? want to keep it as little hackish as possible lol
  7. #17
    Thomas
    West Brisbane
    on my ke i trimed the gaurd lip where the liner fastens to back to about 5mm so that i could dress it up better with hammer dollie [ could almost file finish ], also when you look under there it looks a bit more of a professianal job
  8. #18
    Logan
    Probably a stupid question but when you say you are running MAX castor, which way is considered + and - castor..?
    I'm running 15 x 8 -0 offset 195/50's with xt130 lca's and I had to adjust the castor back so the rims would clear the front inner of the guard..
  9. #19
    Henry
    Eastern
    mysh*tboxke70: Why such big tyres? should run a 50 profile, then you could bring the front down another 30mm or so.
    Try a 195/50.
    Stock ae86/ke70 castor rods should net you about +3.5 degrees.
    It will rub, just get out the grinder and trim the front of the guard.
  10. #20
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    sorry but your exhuast doesnt count for being low.
    FTP.
  1. Best way to flare guards
    By Gabe in forum Technical - Questions
    Last Post: 22nd December 2011, 10:25 AM
  2. Need someone to come out and flare my guards.
    By troy in forum Melbourne & Vic Events and Discussion
    Last Post: 28th May 2010, 11:47 AM
  3. Anyone know of someone who can flare guards?
    By Big T in forum General Topics (No Technical Questions)
    Last Post: 2nd February 2007, 11:03 PM
  4. Those Flare guards
    By Golberg in forum General Topics (No Technical Questions)
    Last Post: 26th July 2006, 10:01 PM
