Results 1 to 5 of 5
Thread: 4AGE lifter size
    Nick
    western suburbs
    Default 4AGE lifter size
    hey, just wanted to know if all the lifters in a 16v 4AGE bigport are the same size?
    thanks
    mark
    central coast
    the lifters are the same size but the shims in the top of lifters are different heights usually. you can use a micrometer to measure them
    Nick
    western suburbs
    are the shims different from factory or is it due to wear and tear ?
    my lifters and shims got mixed up so i am unsure of were they go
    mark
    central coast
    i believe they are different from the factory. if you have a thickness gauge just put the lifters and the cams in and measure the gap. it should be inlet 0.15-0.25mm and exhaust 0.2-0.3mm you'll have to swap the shims around till they are all within tollerences. its not very hard
    Dave
    its not that the shims are different from factory, its the fact that they are measured specifically for the specific valve and lifter.
    its like the old engines with the adjustable rockers, you adjust the valve clearances with the little screw in thing and lock it off with the nut. in 4ages this is done via shims.
    i do not belive it matters where the lifters go, but you will NEED to remeasure the shims for EACH valve. and ensure you have the correct valve clearance.
    - Blaise Pascal
  1. exhaust size for a smallport 4age
    By ae_86_jp in forum Technical - Questions
    Last Post: 24th August 2011, 12:05 AM
  2. 4AGE bigport size
    By ae85 trueno in forum Technical - Questions
    Last Post: 23rd July 2009, 10:58 PM
