Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
Thread: Tough N/A Build....toda,hks,arp
    Senior Member haydenz's Avatar
    Hayden
    Geelong
    Unhappy N/A Build....New Pictors Pg2
    Hi all,
    I have just recently come back from overseas and I have decided to go in a different direction with my 86's and need to get rid of a engine I have been building/storing away the past couple of years.
    I basically brought the engine and had various parts reco'd and modified to suit what I wanted....but I am no longer interested in finishing it, as I dont see an end date, nor the funds to complete it shortly. Saying that I havent been tight on parts so far so here is the list.
    -Bigport Engine Head and Block has been reconditioned.
    -Mild porting has taken place to inlet for better flow/less restriction
    -Upgraded Valve springs (crower cam)
    -Valves and shims have been reset in the head, all ready to go.
    -Crank has been re-ground and has oversized bearings to fit. -professionally cleaned
    -Sandblasted cam covers
    -Refirbished Alternator, hasnt been used cost me $180 to get refirbed
    Price: $600 for everything offers may be considered
    Post: I may post (will be expensive), I will also deliver to melbs for $30 and $50 for anywhere within reason outside of Melbourne.
    Pics:
    Any Questions P'M me or you can contact me on 0431536236 (dont SMS me I wont reply, call me)
    Cheers Hayden
    NOW SPLITTING:
    HEAD $400 ONO. (INLCUDES STOCK & UPRATED VALVE SPRINGS AND SANDBLASTED CAM COVERS)
    BLOCK $300. (CRANK,OIL PAN & MOST OF THE BOTTOM END PARTS)
    REFIRBISHED ALTERNATOR - $130
    I CAN ORGANISE POST, CAN SHIP NEXT DAY. DEPENDING ON SIZE/WEIGHT I CAN GO THROUGH AUS POST OR COURIER.
    ALL SERIOUS OFFERS WILL BE CONSIDERED.
    Hayden
    Geelong
    will separate the cams if anyone is interested????
    Jordan
    Prospect
    price on quads / adapter plate / trumpets
    keen. manitoublack@gmail.com
    Jordan
    Future ride:
    FT-86.
    Current rides:
    CAA22 Celica, 2000 Caldina GT-T manual, 1966 RT40 corona,
    Previous Rides
    86 hilux, 4xKE55's, 3xTA22, RA28, 2xRT40, 2xST185, KE10, 180B, RT132
  • #4
    Hayden
    Geelong
    Quote Originally Posted by haydenz View Post
    90% of the parts are there to finish this off, although I have made a rough list of what needs to be finished on the engine.
    please read the ad
  • #5
    Veteran DAMO46's Avatar
    Jun 2009
    Damian
    what specs are the block to?
    also got more pics of the porting of the head and block?
  • #6
    Junior Member KE35Punk's Avatar
    Aaron
    Thornleigh
    are you selling the Lego with it?
  • #7
    Dan
    Vic
    Western Subs
    Upgraded Valve springs (crower cam) - with or without retainers?
    would you sep?
    . h i t o r i k o .
  • #8
    Hayden
    Geelong
    everything in the head has already been set up to run the cams, it basically needs a couple of bits and peices to get it going.
    I will separate the head from the block.
    Cams - $650
    Head - $400
    Both - $900 and will include ARP Main Bolts
    Quads $210
    All of that $1050
    $1200 for it all
  • #9
    Dan
    Vic
    Western Subs
    crank how much?
    . h i t o r i k o .
  • #10
    Hayden
    Geelong
    $300 and I will give you a free re-cond block with mostly everything bar rods/pistons
  • Page 1 of 3 1 2 3 LastLast
    1. 4age cams, quads, arp hks trd t3
      By timpy in forum Car Parts For Sale
      Last Post: 7th January 2013, 09:21 PM
    2. Engine build issue: CAS shaft hitting ARP head stud
      By maxhag in forum Technical - Questions
      Last Post: 2nd January 2012, 12:09 AM
    3. Replies: 15
      Last Post: 19th May 2011, 12:58 PM
    4. FS: ARP Conrod bolts/ HKS Turbo Timer
      By ae86 drifter in forum Car Parts For Sale
      Last Post: 16th July 2010, 10:40 PM
    5. 4age ARP Head stud Kit, toda 0.8 mm head gasket
      By rxbenny in forum Car Parts For Sale
      Last Post: 10th July 2007, 11:50 PM
