Separate T3 plate!!
Im looking at getting a 3SGE engine setup,so im putting my entire driveline up for sale.
Rebuilt 4age smallport engine, 10,000kms on the engine, balanced rotating assembly etc, but requires new rings. Drives as it is, but has some blow-by. Made 80kw's in it's current state, conservative tune with base timing and cams @ 0. Car was tuned by Shaun @ Boostworx.
Bigport head, slight porting, heavier valve springs, TRD 0.8mm head gasket
TODA 288 8.5mm lift cams in/ex with HKS adjustable cam gears, HKS timing belt
20v silvertop quad throttles and 75mm trumpets on T3 adapter plate with 4AGZE injectors in billet fuel rail
TRD extractors with 2.25 inch straight through exhaust
ADAPTRONIC ECU with full loom and Denzo individual coils
JDM T50 gearbox with HD clutch and 20V lightened flywheel
JDM Tailshaft
T-Series disc rear end,with TRD 2way L.S.D and 4.11 gearset
Also will be selling with it..
JDM EFI fuel tank with Walbro fuel pump thats done less than 3 hours work
SARD Adj. Fuel pressure regulator
Racespec solid engine mounts
Brand new AJPS JDM traction brackets
JDM Radiator and hoses
oil cooler kit
I want $5K for the lot... rough pricing from above is over $6500.....
Buy it, re-ring the motor for under $1K, put it all in and enjoy life. Everything is still in the car, and can be driven right now.
DO NOT ASK ME TO SEPERATE!. I will say when Im separating parts if I have no luck, but really want to sell it all as a complete package at the moment
Car is located in Modbury, SA, not really keen on sending so much gear interstate, but will if the cash is right.
Ring Ben on 0430 395 819, reply here or PM me.
Separate T3 plate!!
ill take the cams gears and shafts if you split
I wont seperate it. If I cant sell it all, Il re-ring the motor and continue with that.
So.......Um T3 Plate??
(If you do end up seperating I would be keen for hd clutch and flywheel)
See above. If I cant sell it all in one hit Ill leave it where it is.
Only way ill seperate the lot is if I have buyers for 90% of it all, especially the motor/gearbox and the diff if im going to tear the engine down i may as well re-ring it and keep using it.
i wish i had the dosh for this
If someone wants to make an offer for the complete engine (Block/head/cams/cam gears/throttles/head gasket/headers etc, basically full engine package minus ECU.) I might be interested...
Ive found a VERY low km 20V blacktop stuffed away out the back of an importer and Id be keen to stick that in if I can get the cash for it, but Beams engine is still on the table.
Ill probably be replacing the clutch and flywheel when the motor is out regardless, so ill let you know when the time comes if you're still keen?
