Page 2 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 11 to 20 of 86
Thread: Rear/Front end shock options
  1. #11
    Senior Member 45aken's Avatar
    Marko
    Those camaro's are a direct fit?
    FKN sweeeeet
  2. #12
    Veteran Konakid's Avatar
    Henry
    Eastern
    Front or rear?
  3. #13
    Joe
    Bellbowrie
    pretty sure its the rear konakid
    stay classy
  4. #14
    Henry
    Eastern
    How, they are both KYB AGX?
  5. #15
    Marko
    what would you recommend then?
    surely the camaro shocks cant be bad, heavier car, agx, 8 way adjustable and very similar dimensions to the tokico's
  6. #16
    Henry
    Eastern
    excel g arent stiff enough for 6kg rears tho, or short enough for sub 230mm free hieghts
  7. #17
    Nic
    Mt Evelyn
    what are sierra shocks like in the back or a e7? im thinking bout putting some in till i can afford some trd items. i will be running pretty short springs
    nic
  8. #18
    Henry
    Eastern
    Too $hort.
  9. #19
    Marko
    ajps,
    what your saying is a little disjointed.
    The camaro shocks at full compression are only like 2.5mm longer than the tokico HTS and extended out 30mm. i have pug 505's sitting in the car now and they're so short it's a hassle to put on 15's when the back is jacked up. i cant see a problem with the heights, and the agx's are adjustable and can be had for quite cheap.
    are you saying there too soft for 6kg springs? even with the agx's?
  10. #20
    Jonathan
    Part of the first post is from what I had written somewhere. This is what I am trying now:
    rear shocks:
    Koni Sport (yellow) adjustable (but the compress and turn style adjustment)
    to suit Paseo and '96-'99 Starlet
    ext = 484mm
    com = 317mm
    Don't eveyone go and buy these yet, still have to test. Only got them because they were cheap on ebay (old stock) and I saw they were the right length. You have to swap the lower rubber bush.
  1. Front AGX shock options for LOWDOWN
    By blair in forum Technical - Questions
    Last Post: 5th September 2011, 11:24 PM
  2. Replies: 0
    Last Post: 23rd June 2011, 11:59 AM
  3. Front shock options
    By drift kid in forum Technical - Questions
    Last Post: 21st December 2009, 07:33 PM
  4. rear end options
    By starni_boy in forum Technical - Questions
    Last Post: 24th January 2007, 08:11 PM
  5. Front shock options
    By damo_00 in forum Technical - Questions
    Last Post: 11th January 2007, 05:57 PM
