But i doesnt say the OD size of the insert.
Read the post!
Theres 2 others i am asking for cheers!
hey might not be of any use but st132 corona wagon rear shocks arfe perfect in a mx32 cressida, 6-7 inches shorter, and with a captive spring it will leave you about an inch of room between tyre and guard,
also sierra in ke55, leaves that at anout the same height, you need to get your flip on with the leaves tho
just did a test fit of this today, vw rabbit/golf shocks fit the ae86 strut, are short stroke and are available in bilstein. im going to cut my struts to fit them tomorrow, but everything fits, not the same gland nuts though - same size but different threads (can buy ae86 gland nuts to suit tho), ill measure them up lengthwise tomorrow but i think its about 80mm shorter body than standard ae86 shocks.
Can anyone tell me the compression and rebound of the Celica 365077??? From what I've found they are similar length to trd yellows 48511-ae941 but I wanted to find out just how different they are?? Being ALOT cheaper in price I'm guessing they are nowhere near as good..?
Will be running 7kg springs on coilovers.
i will be using sw20 shocks in my corona struts once they are shortened and coilover sleeves welded on with 6kgs
and rear commo wagon shocks with 4kgs
what model shocks for the back of a RA60?
and what model ford springs?
read most this thread a few times but still dont know wtf to use, these are my springs in my car and would like to know best option to work with these springs
Front AJPS springs 8kg 210mm
AJPS rear springs 6kg 220mm
Front shocks - whats good for these springs? is there any DIY jobs that needs to be done with the shocks you have mentioned
Rear shocks - whats good for these springs? is there any DIY jobs that needs to be done with the shocks you have mentioned
dose
depends budget and what you wanna use the car for
