Results 1 to 4 of 4
Thread: Oil Temp
    Default Oil Temp
    Hi Guys,
    I'm new to the hachi scene,
    Just wondering on how hot the oil temp should be on an AE86 engine.
    On my stock dash i am getting half at idle and 2/3's when driving.
    Too me this seems way too hot. Anyone know what i should be looking at replacing or checking?
    Thanks for your help
    Senior Member amulday's Avatar
    Amulday
    Central
    Oil temp sits on about 80/90 casual driving (in summer), Hard driving in summer it's seen just past 110. That's without an oil cooler.
    I don't trust the stock sensors and gauges in the car, Get yourself a sandwhich plate for the oil filter and hook in an pressure and temp gauges, do water temp while your at is as well.
    amulday.sam
    HR ARMY
    RED BEAR
    If you are talking about the Gauge on the stock dash, that is actually oil PRESSURE. The measurements you have given are quite normal.
    In regards to oil temps. amulday is on the money.
    In regards to overall temps. you want your Water temp needle to be just under halfway. if it gets to half this is OK! anymore is a sign that something isn't functioning right. Airflow (path is blocked by something?), Radiator (Is this blocked, corroded etc). Water pump (Check the pulley with the belt of to see if it wobbles, any leaking of coolant in the area).
  • #4
    Thanks Matt,
    Well thats embarrassing i thought it was oil temp ... lol
    Noob mistake
  • Similar Threads
    1. Replies: 4
      Last Post: 16th May 2011, 01:13 AM
    2. WTB: Gauges, Oil Temp, Water Temp, Oil Press.
      By Robo86 in forum Cars or Parts Wanted
      Last Post: 30th July 2009, 09:16 PM
    3. FS: Omori Oil Pressure & Oil Temp Gauges
      By Nebuchernezzer in forum Car Parts For Sale
      Last Post: 14th November 2007, 07:50 PM
    4. omori oil filter relocation kit with oil temp and pres guages
      By ae86 slide in forum Car Parts For Sale
      Last Post: 21st March 2007, 07:04 PM
