GTX2 seems to suck.
Anymore recommendations for the 22re?
GTX2 seems to suck.
Shell Helix Plus 15W-50
will change to new oil once every more or less 3k on mileage, car is daily too
free stuff from work, mobil 10 40w i think? semi synthetic
not sure, does the job
hahaha
elf 10w-40 semi synth in the SR
its the stuff i get from work cause its free.
beams 3sge, adaptronic, zorst, intake
penrite sin 10
Free stuff from work for my cars, Shell helix racing 10W-60 or Selenia Racing 10W-60
what is the stock oil grade for small port map 4agze?
also
what is the stock oil grade for JDM T50?
thanks
im a 3rd year mechanic at toyota i have 2 ae86's 1st my daily JDM import 4age bigport with a few little things like a full exhaust, bigger fuel pump and lines i run castrol 15w-40 in that it doesnt see the track but i do take it out drifting and ive had no problems with it, 2nd is a track car 4agze bigport out of a mr2 converted to turbo the motor has just been rebuilt with ross rings and 8.6:1 forged pistons that are 1 size up spool h beam rods, all ARP main cap bolts and head studs, cometic head gasket 272 cams valves are 8.6mm lift titianium retainers and all new springs etc i only got this 1 the other day though and it needs a tune because its only just been put together and still running the tune off the old stock motor. The guy i bought it off was a mechanic and has been racing cars for a while said he put Castrol edge 5w-30 in it.
