Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: Coilovers:(
    Veteran corknose's Avatar
    Callum
    Default Coilovers:(
    Car - ke70
    motor - 4age
    use -street daily
    problem -my coilovers suppoivly leaking gas and knock
    occurs/started when - i pretty much bought the car
    personal situation - when i drive along my coilovers make a weird knocking noise and sound like they will fall out ive been told that the shock is leaking air and its fucked cause they were cut n shut too short.
    would it be that or just the bearing on top of my camber tops? n is it dangerous to drive like this?
    cheers cal.
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    how much stroke to they have ? tighten the gland nut that holds shock body in REALLY well or else it will make a vibrating/rattle noise which will sound horrible.
    also nut ontop of camber tops with a rattle gun if u havnt got one tighten as much as u can when car is on ground and has weight on it then hit it round a few times with a hammer!.
    take it out make sure its all tight put it back in take it for a quick drive, while their out take em appart see if any oil is leaking, could be a blown seal,
    Davey & Riki-lee
    South Australia
    Seaford SA
    yeah make sure she is tight, mine came loose the other day and i was freaking out haha check that and do you inserts have spacers?
    Our introduction - Click here
    Callum
    i dont think so if so where would they be?
    Davey & Riki-lee
    South Australia
    Seaford SA
    well you gotta take the whole strut out but i wouldnt worry it props isnt that, check the nut is no1 big pair of grips
    Callum
    just the nut on to or the gland nut?
    Davey & Riki-lee
    South Australia
    Seaford SA
    the big nut holding the shock on and the one on the strut top nut aswell
    Callum
    aight ill give that wurl tomorrow. thanks heaps
    Moderator
    Jay
    check that they are spaced properly. mine were knocking because the gland nut couldn't be fully tightened, added a 2mm spacer beneath the insert and its fixed
    Davey & Riki-lee
    South Australia
    Seaford SA
    thats what i ment by the spacing, when you do it up fully and tight check it it moves up and down and side to side, if there is play you need to take the shock out and add a spacer
  1. Replies: 9
    Last Post: 31st May 2011, 05:47 PM
  2. S13 LCA's S13 front coilovers and AE86 rear coilovers
    By Brendan in forum Cars or Parts Wanted
    Last Post: 8th April 2010, 01:11 AM
  3. coilovers
    By chaff in forum Car Parts For Sale
    Last Post: 11th January 2010, 01:32 PM
  4. coilovers what do you think of these?
    By slippry in forum Technical - Questions
    Last Post: 27th October 2006, 04:04 PM
  5. coilovers
    By Wanabe_Garage in forum Technical - Questions
    Last Post: 4th August 2005, 01:56 PM
