Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
Thread: New Project.
    Sep 2009
    Trav
    Port Adelaide
    Aus
    Default New Project.
    Hey there, I'm Travis, this is my first post. Bought a Sprinter off some old guy a while ago, 1 owner. Original as it came. Have been looking for a clean one for a while now to build up a solid street/track/drift car.
    As I have limited knowlede of the intricacies of the AE86 any advice or suggestions would be awsome.
    So far i have got a rebuilt jdm rear end, adjustable panhard and upper and lower arms. Advan 14 x 6 rims (just to begin with) And have gutted the car.
    TO GET? (please help)
    Have my eye on a Full HKS headders and exhaust from japan
    Adjustable coilovers all round and cambertops at the front seem the go?
    Front and rear strut tower braces, tri bar at the front possibly?
    Also a heavy front sway bar
    Any little bits more i need to get? roll centre adjusters for the front?
    Clutch/flywheel
    Have a low k's 4AGE bigport to go in. Tossing up putting it in stock and gradually building it up or have it off the road longer and do the job. (quad throttle body, computer, cams, bottom end, ect) Im starting out on the suspension and handling before i get to the engine.
    Really want this thing up and going by the end of the year Wishful thinking maybe?
    Sep 2009
    Trav
    Port Adelaide
    Aus
    In the beginning...........
    Project is well on the way.
    JDM Rear end, lateral rods, panhard, megan suspension all in.
    Rims have come up well, better than when i got em anyway.
    Quads....I'm getting there, q's to come no doubt.
    Veteran Touge Boy's Avatar
    Modbury
    Nice car Travis....
    Here's my advice (So dont take it as gospel haha)... trying to follow your questions in order...
    Have my eye on a Full HKS headers and exhaust from japan
    I would just get a set of TRD copy headers and a 2 or 2.25 inch exhaust made
    A lot of people will tell you to have a custom set of front coilovers made, and some good springs and struts in the rear.... Im using the BC coilover kit and for the cash... Im not complaining. A few places can bring coils in from japan, others will make their own kits up here. Also search around the parts for sale thread... few sets for sale on there.
    Although there is a lot better gear out there like HTS Tokiko, TRD Blues, Bilstein, KYB AGX etc. but a lot of them come with the pricetag.
    I use a front tower bar only. But a rear one would make a difference too. Up to you.
    I only run a front aftermarket sway ATM, but Im buying a aftermarket rear in the next fortnight or so.
    I think RCA's are a must if you lower it.... General rule of thumb is the use the same thickness RCA as you drop the car, ie. drop the car 25mm, 25mm RCA etc.
    Also look at some castor arms, check all your bushing isnt perished, maybe a good set of pads and some braided lines.
    Clutch/flywheel
    run something like an X-Treme or Exedy single plate clutch, Maybe get a lightened flywheel with it if you can afford it.
    If I was building it... i would put the 4AGE in as is and learn to drive it, even stock they're still effective. My car already had the built motor/cams/ecu/quads etc when I bought it.Sort the suspension/chassis/braking before you go for more power. You'll be better for it in the long run
    Hope that helps.
    Timmy D
    North
    dude that looks like such a clean shell! nice work. looks like you already have some tasty parts installed
    also make yours pics smaller
    JJ
    Veteran skizzamods's Avatar
    Oscar
    Adelaide Hills
    re-size pics!!!
    oh and looking good
    Senior Member bams_keto's Avatar
    Stephen
    Sutho Shire
    second that!
    i can't see shit
    Veteran Beau's Avatar
    Beau
    actually could you make your pics bigger please i love it big
    Sep 2009
    Trav
    Port Adelaide
    Aus
    OK, I'll try again, I suck at forum,ing.
    [ATTACH][ATTACH]
    [ATTACH][ATTACH]
    [/ATTACH][/ATTACH]
    [/ATTACH][/ATTACH]
ID:	7676   Click image for larger version.
ID:	7677   Click image for larger version.
ID:	7678   Click image for larger version.
    E-Famous (Remeber your roots)
    What shall you be doing with this car?
    Sep 2009
    Trav
    Port Adelaide
    Aus
    Having a lot of fun!! Try my hand at drifting. If I suck I'll still have fun. I've lived driving & riding through the hills so i'm sure the car will have many uses.
  1. W.E.R.D #3 from Project D
    By MeZ Prod in forum The Drift Channel
    Last Post: 20th September 2011, 07:58 PM
  2. Project D
    By starni_boy in forum AE86 Owners Forums
    Last Post: 22nd June 2008, 05:35 PM
  3. New Project
    By Andrew in forum KE70 / AE71 Owners Forums
    Last Post: 7th February 2007, 09:41 AM
  4. My new project
    By Sledpilot in forum General Topics (No Technical Questions)
    Last Post: 4th January 2007, 05:58 PM
