which t-50?
any one know if the 4 age 100kw clutch will fit a t50 gear box or you need sum custom stuff
which t-50?
you need to use an ae86 or ae71 RWD 4ac release bearing and you need to put a spigot bearing in the end of the crank shaft. I think its a 6000 (or maybe 7000) bearing.
Make sure when you get you clutch that it suits your fly wheel size.
As in if you get the motor from an ae92 it will have a 212mm flywheel and clutch.
The ae71 or ae86 4ac will have a 200mm clutch and fly wheel.
So if you are putting a ae92 4age into your ae86 you need a clutch to suit an ae92 not ae86. and get them to swap the release bearing that comes in the ae92 package for an ae71 release bearing.
Also I will give you some really good advice.
At least try to use the template for tech questions.
I know it sounds pissy but I'm telling you now people will flame the shit out of you for it and usually you won't get an answer!!
So if you expect someone to spend their time typing up answers for you then you should at least invest a bit of time making it easy for them to read and answer.
Again I know it sounds pissy but you've already had this thread locked once and you just made another without bothering to make it readable.
thankz guys sorry coz im just new to this
