Results 11 to 20 of 24
Thread: How to remove rear hub?
  1. #11
    yeah.. jap t series
  2. #12
    Jay
    its all one piece it is forged to the axle, best way to do it is remove the 4 bolts at the back of the axle then get a shit rim and bolt it onto the hub and hit it to take it out
  3. #13
    then how bout to put back in?
  4. #14
    User fantapants's Avatar
    Pat
    you put t back in and do up the bolts.... aint rocket science billy bob
    your taking out an axle... your putting in an axle... go and do it and you will learn a lot more than sitting here asking about hubs
    06/07/2011
  5. #15
    yeah one of my bolts on the rear thing is threaded so i wanna go get a new bolt put in it.
    i cant take it out though..
  6. #16
    Jay
    yea you just slot it back in, it will slide back into place and then you just do the axle bolts back up and keep putting the rest back on
  7. #17
    any ideas on how it can come out cause i dunno but motivations not the way
  8. #18
    Pat
    bolts on the thingy????
    if you mean the wheels studs..... they are pressed in.... just hammer them out....
    other than that, make sure all the bolts that hold the axle and bearing in the housing are undone and off.... then use a slide hammer if you have one, or a old wheel. i used the drum housing inverted on mine..... llosely do up the object ( tight for slide hammer ) then sharply yank for all your worth.... a few hard tugs and it should pop out.
    if not, a bit of sharp work with the hammer....
    none of this needs doing if its only a wheel stud?????????????????
    06/07/2011
  9. #19
    Senior Member Oly AE86's Avatar
    Oliver
    Logan Shire
    To remove axle you can use a slide hammer.
  10. #20
    yeah thats all it is fanta pants so i can just hammer them out?
  1. How to remove T50 rear gearbox seal?
    By kyle unwin in forum Technical - Questions
    Last Post: 8th July 2012, 03:19 PM
  2. how do you remove a stock 86 rear bar
    By hachi_dk in forum Technical - Questions
    Last Post: 14th December 2009, 11:20 PM
  3. Hot to remove Rear Bumper
    By Sprinterboy in forum Technical - Articles
    Last Post: 27th January 2009, 01:28 PM
  4. How to remove the Stock Rear Bumper
    By rlnbye in forum Technical - Articles
    Last Post: 31st March 2008, 02:01 PM
  5. Help - 3 RHS rear hub stud threads ruined AE86
    By Sidey in forum Technical - Questions
    Last Post: 16th March 2008, 11:00 AM
