Results 1 to 10 of 11
Thread: help!
    alex
    Default help!
    allo! just a quick one, when converting a ke70 from slant to flat front, how do the headlights bolt up? Do you need to change the radiator support? Any help would be awesome.
    Cheers!
    YAZE
    alex
    no one?
    Hugh
    i think you have to change radiator support..but I may be wrong don't quote me, but im pretty sure thats the best option
    drill new holes?
    check rollaclub.com . i remember seeing someone do it there.
    alex
    ive made a few searches on a few different forums, ive found a little bit of info, not alot though. Theres gotta be someone on here whos done the conversion and can give me a couple of hints? I would assume the quad lights conversion would be the same
    Need to change the beaver panel I think. I think thats what its called, total memory blank right now. Its the bit thats just behind and below the lights. Runs vertically, I think people just modify them.
    alex
    ive got a flat front one, its just the lights i cant work out. the slant ones have a bracket on the outer side and bolt up in completely different spots, on the rad support. So, do I need a flat front rad support? drill new holes? make brackets? how does everyone else do it...?
    性交を愛する
    You need to change the Radiator support. Or you can make a bracket to fit the flat front lights.
    alex
    so drilling new holes is definatly out?
