What deck is it?
Hey guys,
Bought a new CD player for my car just before, and i opened it up and the wires for the back were all chopped, and it looks like ya have to fit it yourself. Can any1 from adelaide or SA help me with fitting it? ill shout ya a 6 pack or 50 bucks or sumfin for the help. Just a question, if ya can help PM me
Thanks guys
Hazzard
Thanks,
Andrew.
What deck is it?
if you have a basic idea on electricals, it aint hard to wire up
acc
ign+
earth
speaker wires
is all the wiring u need to know and how to find which is acc and ign+
PROTEK TYRE AND AUTO
SQ ENGINEERING
NCCE
It's actually, batt, acc and ground. KE70's don't have a batt wire at the radio plug so you're gonna have to tap that off somewhere and run it the head unit.
well, the thing is i barely even kno anything about electicals. so hence the idea i was askin for help..... any1 got a spare satdy this weekend?
Thanks,
Andrew.
See if you can find a manual on the web first - do a quick Google search to start off. They usually have pretty good installation instructions and will help you match the right wires up.
4AGE is here! Cheers 44GTE and Anthony for your help! http://www.ae86drivingclub.com.au/fo...ad.php?t=10384
AE86 Driving Club Official Rules -please read!
What am I doing right now? Twitter me!
ok so ima try help with my noobness experience with installing CD players
NEED!!
- test light
- CD player and plug that comes with it
CD player should have come with like a installation papper or something to identify the colours of the wires
FIRST wire you want to connect is....EARTH
you can wire the CD player earth to another wire from the car loom that is an earth already... i simply just run the earth wire under a screw that is holding some plastic interior thats touching some metal/main body of the car...
next, i try to find the CONSTANT power wire,and wire this up. This is what keeps the memory of the CD player..example..saving the settings of your boom boom beat, or ur radio tuner, 96.1, 96.9, 104.1 etc..
then find the on, ignition, what ever you want to call it, wire...this wire TURNS ON the cd player when you turn the keybarral...so with a test light...turn your car onto REDS and find a power wire that lights up the test light when you do this...that should be the wire your after...
once these 3 wires a done...test it by turning it on and off...saving your radio station etc...make sure its working...
speaker wires are easy...have a dummy speaker with you if u can..
eaiest way to do this is...set ur CD player to play only to the front speakers...then connect the dummy speaker and you;ll soon find out which wires from the cd player are for the front speakers....now make your CD player play from left to right and out of the 2 front speaker wires, you'll know which on is left and right
back speakers are the same...make CD player play at the back and find out which wires are left and right..
put everything back and you should be sweet
refer to the installation paper or wire papers if you get confused...its to simple to just let someone else install it for ya =b
dose
to add
perhaps try finding a a plug adaptor from jb, repco or super shit so you dont have to hack into the loom to join the wires + run new wires if you arent going for a super duper awsome stereo
ok, thanks dudes its ok now one of my mates finally decided to get off his arse and help thanks for all the help.
Cheers,
Hazzard
Thanks,
Andrew.
