seperate the jun cam gear?? got any more detailed pics?? comments on them?? considering them myself instead of toda...
hey guys I have a 20v ST head work done by ABBOTS engineering on the goldcoast
JUN adjustable cam gears
big port work both in and ex
KELFORD cams form NZ bro
YAGER PERFORMANCE valves and heavy valve springs
ACL race series bearing
a set of ARP head studs (thats 2x 16v kits but you only use the long bolts)
GATES timing belt
and COMETIC steel head gasket
20v rwd water relocation kit
20v match ported 25mm thick alloy plenum flange (for making a new plenum)
20v exhaust flange
head has never been run everything is still brand new (its alltogether tho)
$3500 ono will post at buyers expense
im located in jimboomba south brisneyland
contact me via pm or call / txt me on 0407216463
MY AE86 BUILD
i havent had the engin running or any thing but there pretty good there just not as fancy looking as toda ones thats all i can say there still quality construction
o and i wont seperate
what is duration and lift on cams please?
assuming the valves are not oversized? (as not mentioned)
and with these cams/gears is VVT still usable or negated?
doent use vvt with those cam gears
valves are not over sized
cams are these \/\/\/\/
Yeah I found but list 6 versions of 20V cams (and custom):
266 duration, 8.29 lift. Fast street cams
270/280 Duration, 8.72mm lift. Rally cams*
284 Duration, 9.35mm Lift. Mid lift Racing Cams
288 Duration, 10.00mm Lift. Racing Camshafts
300 Duration, 10.50mm Lift. Ultimate Racing Cams
268 Duration, 8.28mm Lift. 20 Valve 4A-GE stage one turbo cams.
that link takes you straight to the ones i have but its the 194-B rally cams
bump !!
bump!
