Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: Another Offset Thread
    Senior Member lo_rolla's Avatar
    Damien
    Brissie
    Default Another Offset Thread
    Sup homies.
    So I found some wheels I wouldn't mind having on my Hachi.
    15x9 -27 and 15x11 -27.
    I don't think they'll fit, but I'm being peer pressured pretty hard here by some buddies.
    Things to know front I got pretty much all the AJPS gear and 30mm Dmax gaurds, so the fronts SHOULD fit, right? And at the rear I got Origin Lab 30mm Flares.....
    Thanks for your help, handsomes.
    Damien.
    性交を愛する
    Planned on getting well raped by the cops?
    I'd imagine they would fit, how low do you run the car?
    what a name damo
    Senior Member Dylan's Avatar
    Dylan
    pics?
    Veteran Konakid's Avatar
    Henry
    Eastern
    Fronts would fit with camber and a 195/50
    No chance on the rears even if you had 50mm guards as you'll need to run a 205/50 or bigger.
    Damien
    Brissie
    I knew you would come through for me Kona.
    ...before I wasted 2200+.
    Back to the equip 01 idea.
    Henry
    Eastern
    30mm front and rear could fit with stock lca's and -2.5 camber:
    Equips come in
    front 8.5 -25
    rear 9 -18
    with 195/50's would be so hot.
    性交を愛する
    Just do it.
    Veteran johl's Avatar
    Johl
    dude get those meshies. they ook awesome and are virtually brand new. even if give up on the 11's at the rear im sure they'd be easy as to swap
    could always go CBY or something in the rear
