Results 1 to 10 of 13
Thread: 86 pedal box into ke70
    Senior Member Brendan's Avatar
    Brendan
    Default 86 pedal box into ke70
    Hey guys, has anybody modified an 86 pedal box to fit a ke70?
    ive got one coming for mine and i could do with some advice for fitting it in.
    if it doesn't want to fit im gonna make it fit regardless because i still think it'll be easier than modifying my old ke70 set...
    I probably could've sorced an AE71 box but im too impatient for that so i went with the 86 option
    If there is enough interest i will post up my progress and try and help others who journey down the same path
    Thanks guys...
    Senior Member Simon-KE70's Avatar
    Simon
    wont fit without some mods. Bit of work needed to make it fit really. you'll need a welder and some bits of steel to make a bracket.
    easier to make a T18 one fit. or even less work to mod the KE one to suit a Hydraulic master
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    just ghetto it up man, few self tappers and some paddle pop sticks.
    FTP.
    Brendan
    yeah we got plate steel and a mig at the workshop so i might go for that option
    i think ghetto is the way to go but if any body wants to see how i ghetto it up let me know and i'll do a "bush mechanics" post up of the whole thing
    Brendan
    so no ones seen it done?
    Veteran slydar's Avatar
    Dimitri
    ive done it. if you have a mig and some steel, its not that hard. just take your time getting the placement right.
    there it is.
    Senior Member greeneyes's Avatar
    Vlad
    Sacred Valley
    Cusco
    Peru
    I've just swapped a manual KE70 into my auto. A bit of a mission getting them in and out..
    Why the AE86 pedals?
    http://www.ke70.com/forum/index.php?...t=0&#entry9485
    Dimitri
    because if you want to use a 4age with a t50 for example, you will need a hydraulic clutch set up.
    ke70 is cable. ae71 is hydraulic, but rare and expensive.
    Dimitri
    should not the car i converted was orginally auto.
    this photo
    shows the difference in pedal boxes. you might need to hack it up a bit to make room for the 86 pedal.
    Vlad
    Sacred Valley
    Cusco
    Peru
    Ah- I see. There is an '84 AE71 at the wreckers here in Orange with a clutch cyl & pedal box in... $90 plus pstage would buy it, not sure if that's expensive or not.
  1. Ke70 pedal box
    By sundee in forum Cars or Parts Wanted
    Last Post: 15th February 2010, 03:07 PM
  2. 86 pedal box thingo
    By Drift_Donkey in forum Cars or Parts Wanted
    Last Post: 8th February 2010, 05:04 PM
  3. T18 Pedal Box insted of AE71 Pedal Box????
    By ke70 xx in forum Technical - Questions
    Last Post: 8th May 2009, 04:08 PM
  4. pedal box ke70
    By fozz in forum Technical - Questions
    Last Post: 22nd October 2007, 01:43 PM
  5. ke70 pedal box
    By Gavin in forum Technical - Questions
    Last Post: 3rd September 2007, 12:21 PM
