Results 1 to 6 of 6
Thread: Shocks for coilovers
    Senior Member stouty's Avatar
    Leigh
    Forster
    Default Shocks for coilovers
    Im looking at doing a strut converted coilover set up with 7kg springs in my TE72. At the moment it has cut king springs and KYB excel g shocks.
    I was wondering what people can suggest shock wise for the new set up or just use the existing shocks?
    Grip TE72
    http://www.ae86drivingclub.com.au/fo...read.php?t=276
    AJPS for all you Toyota goodies
    Jonathan
    Get something with adjustment. That way hopefully they can be made stiff enough to match your springs. Standard replacement shocks won't be quite stiff enough to match the 7kg/mm springs, but maybe borderline acceptable. Best to buy shorter shocks also.
    Veteran slydar's Avatar
    Dimitri
    kyb agx st185 only way to go.
    ive used trd blue, yellow, and tokico hts.
    agx are win. cheaper (especially now) than all the japan brands, same quality, plenty stiff, and the bit extra stroke compared to the jap inserts means you get a bit more useful range of adjustment, and you dont need to space the insert at all, just chop your struts down to suit the agx.
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Dim did you end up making up a new set of fronts with the gaz shocks you were gona use a few months back?
    If you did, how did they go/compare?
    BENT MECHANIX - Garage 20:
    Veteran Konakid's Avatar
    Henry
    Eastern
    Quote Originally Posted by slydar View Post
    More info! haha
    whats the stroke like on the AGX compared to TRD Blues?
    Shorter then the Excel G short stroke fronts?
    KYB's are made in japan aren't they?
    Leigh
    Forster
    sweet thanks guys sounds like agx are the way to go
    Grip TE72
  1. DMS High Performance Shocks and Coilovers!
    By gslrallysport in forum GSL Rallysport
    Last Post: 1st December 2010, 03:24 PM
  2. SYD - Front Shocks for AE86 Coilovers
    By civa in forum Cars or Parts Wanted
    Last Post: 21st May 2010, 09:14 PM
  3. what shocks for jic s13 coilovers. help me out??
    By bradae86 in forum Technical - Questions
    Last Post: 4th August 2009, 11:12 AM
  4. Shocks/springs VS Coilovers
    By -=GOODY=- in forum Technical - Questions
    Last Post: 26th February 2008, 09:04 PM
