Any one interested will split up computer,head and bottom end if there are buyers.
4age 20v silver top full build and adaptronic comp with engine loom
4age 20v
block chemically cleaned, crank linished,Valves polished and minor port work
cam grind by sure cam 291 inlet and 298 exhaust(with lift report)
adjusted buckets and hard face shims(1mm)
wiseco 11:1 forged pistons
arp bolts, clevite bearings,newseals allround
toda adj cam gears
serviced injectors
set up for RWD dizzy cover and water routing
trumpets from Meridian motor sport
rwd alternator
flywheel machine and step faced
excedy 4puck clutch
starer motor
I have receipts for all engine work
Adaptronic Computer
computer with silvertop program on it
Loom just needs 4 wires spliced in all plugs and igniters inc (purchased from Kaizen)
This Enigine has not been started and i have spent well over $8000
comes with all the 20v bits and pieces.
Ermington NSW
$4500 ono
Pm
Want!
Bump!
how much for ecu and loom?
