Results 11 to 20 of 26
Thread: EOI: 4age re-build thread
  1. #11
    Veteran slide86's Avatar
    Huw
    Hills
    Time to spin the engine over and get the head on!
    This is the head gasket i will be using. It a HKS item measuring 2.0mm in thickness.
    Part number of HKS head gasket: 11116-018158AO
    Now time to put the head on!
    The head has been faced, New shims, new valve stem seals, fully cleaned.
    Its the standard big port head from the engine with the standard big port cams.
    Here is the head sitting on the block, has not be tensioned down yet.
ID:	805Click image for larger version.
    A quick picture of the top of the head before anything goes on it. Buckets and shims already installed by engine machine shop.
    Now time to install the cams. You cant mix them up because the exhaust cam is the one that has the distributor/CAS drive on it. I lubricated all the journals and lobes before installing, as well as the caps and the head.
    Its a good idea to install the cam seals in the front caps before you tension them right down, otherwise they can be damaged if trying to hit them in afterwards.
    Time to fit the front cam belt cover and the cam gears. Im using the standard gears at the moment but there will be a pair of adjustable gears making there way there soon. Its a very good idea to use loctite or similar on these bolts.
  2. #12
    Huw
    Hills
    Time to fit up the water pump. Im using the one of the motor, not sure if its the genuine one or a mix n match for the RWD conversion. It seems to work ok tho. I gave it a coat of heat proof paint, just makes it look a bit nicer.
ID:	811Click image for larger version.
    Timing belt is the next thing on. VERY important to ensure that you have the cams lined up in the correct position before you put the belt on, also having the crank lined up too!
    There are a few water housing that need to be fitted up, on at the front and one at the back. Ensure to use the gaskets and i used threebond to ensure they seal.
ID:	814Click image for larger version.
    I painted the rocker covers to make it look a bit neater. Its just heat proof paint, but i think it looks alright. Im not really into chrome and all that. But I did pick up some bling bling in the form of an oil cap. Got it of ebay for $6.00
ID:	816Click image for larger version.
ID:	817Click image for larger version.
    Now, the interesting part. I was determined not to use teh stock inlet manifold. I picked up a genuine RWD manifold cheap so i thought i would use this instead. BUT it doesnt fit! Time for some modifications....Basically I retained the factory mount, I just spaced it out and lowered it by about three inches.
    It looks a bit rough at the moment, but ill clean it up and paint it all. It actually works well and its quite secure and tight.
  3. #13
    Huw
    Hills
    im tired now, have to get up soon
    feel free to ask questions and leave comments. ive rebuilt bout 60 LS1's as well (yes SIXTY), i wouldnt say im an expert, but a standard to mild rebuild im capable of id say
  4. #14
    Veteran slydar's Avatar
    Dimitri
    your post is too big i refuse to read it. but looks like youve nailed it.
    can you hook us up a cheap ls1 for my hot rod project? (not kidding actually..)
  5. #15
    Huw
    Hills
    if you had asked me that 3 years ago i could have got you a complete engine for 500 bills....
    we had a stack of 12 at work!!!!
    i can still get all parts for em super cheap
  6. #16
    Scammer, DO NOT BUY FROM ME!
    this is an awesome thread!!
    should put those posts of slide86's into its own thread and sticky it
  7. #17
    john
    nsw
    liverpool
    thanks for all the info guys . had a qiuick read through the 4age manual aswell ... i gotta say it very detailed ... which good i guess. .doesnt seem to hard as well.
    for a frist timer . like my self. should i not touch my unopened running 4age .. and open up a blown smoky engine and practice on that until i get a feel for all the parts and where they go ?
    oh +1 on the sticky ... awesome info on here.
  8. #18
    Senior Member KE70's Avatar
    Alek
    Lalor
    Its easy, me and my bro rebuilt the engine by ourselves by using the manual.
    We had a mate lend us his ring compressor and some industrial assembely lube but other then that it was easy.
    I guess if you need to install new pistons it will be a bit harder.
  9. #19
    Dimitri
    wouldnt start with a fucked one if you plan to use it. easy and cheap enough to get a runner. plus it can end up being much more expensive, and in that case hard to justify.
    that said if you just wanna pull it apart so see whats inside.. with no pressure of it going back together and needing to run, do it. ive done it before. worth a few hundred bux for the experience. will make you less intimidated when you do it for real.
  10. #20
    Dimitri
    slide.. maybe you should mention, when fitting the piston/rod assembly, to insulate the rod bolts so you dont score the crank?
    its very possible to install them without doing this, but for the uninitiated probably still a good idea, its one of the few precautions really worth bothering with.
  1. Lloyd Smith's 1UZ-FE AE71 Drift Car Build Thread
    By bradsm87 in forum KE70 / AE71 Owners Forums
    Last Post: 10th November 2016, 11:37 PM
  2. EOI: Robo's AE86 Coupe PART-OUT Thread.
    By Robo86 in forum Car Parts For Sale
    Last Post: 8th November 2011, 11:15 PM
  3. Lancer Evolution 5 R/C build thread
    By AE092 in forum RC Sports Forum
    Last Post: 23rd June 2011, 04:35 PM
  4. is there a build thread on this??....
    By corey70 in forum General Topics (No Technical Questions)
    Last Post: 25th September 2009, 07:45 PM
