eeww......
ok heres the deal.......i 'modified' these to fit my st141 struts when i was going to run that setup.
basically i have just dremelled out the holes to the same hole spacing as later strut sizings.....pretty much the same as the AJPS rcas you can get for these cars.
i know its not the best idea.....but it worked and they were very secure when i had the setup on my car.
here is a photo comparing standard ps arm and the modified ones....
(the normal ones arent for sale.....so dont even ask)
i want $170 posted anywhere in aus
im in adelaide, PM or 0406004171
eeww......
found out they are arm length 115mm compared to mine which are ra60 P/S 125mm and stock corona 145mm.
Would make a bit of difference i guess, pity wheels already rub at full lock.
yeah just measured it then......115mm is correct.
price drop to $155 posted
