bump. Need these gone
Time for a clean out of all my 4AGE bits. Parts are located in Hornsby Sydney and can be picked up from Gladesville during work hours. Send me a pm or contact me on 0403836849. First in best dressed.
1. T40 gearbox (ex ae71)
Bought this off here about 2 months ago. I have never used it but was told that it was in good nick with not problems. Comes with shifter, bellhousing, clutch fork and thrust bearing carrier. No slave cylinder. The 4 bolts that hold the shifter plate onto the box are missing but these shouldn't be too hard to obtain.
Good to use as is for a drift hack as the 4 speed boxes are a bit stronger than a t50 apparently or you can use it for the bellhousing & clutch fork to put that t50 you have that doesn't have a bellhousing for behind a 4age.
Price: $80. Will not post. You are welcome to get a courier to pick this up.
2. 100kw 4age throttle body & TPS
Got a 100kw 4age throttle body with the TPS up for sale. Came off a working engine.
Price:$50. Will post at your expense.
3. RWD? water pump. Bought this a while ago as a RWD pump but someone has now said that it appears to be a FWD pump so I make no guarantees. Price adjusted accordingly.
Used water pump. Very good condition and has not had much use. As is.
Price:$10. Will post at your expense.
4. 4AGE RWD water pump back section
Used 4AGE RWD water pump back section. As is.
Price:$60. Will post at your expense.
5. 4A FWD water pump back section
Used 4A FWD water pump back section. As is.
Price:$5. Will post at your expense.
6. 4AGE RWD water intake x 2
Used as is. Good condition. Pictured one is clean the other one has the slight oxidation on it which will clean up easily
Price:$20 each. Will post at your expense.
7. Sold
8. 4AGE RWD water pump pulley
Used as is. No chips on pulley
Price:$35. Will post at your expense.
9. 4AGE RWD crank pulley
Price:$45. Will post at your expense.
Pic to come
10. 4AGE RWD air-conditioning bracket?
Used as is. Pretty sure this is an air-conditioning bracket. Off RWD 4age
Price:$20. Will post at your expense.
11. Sold
pm'ed
dose
bump.
bump .
consider number no:7 sold to me pm sent
