Results 1 to 8 of 8
Thread: 4ac pre-ignition
    Member Aezion's Avatar
    Seb
    Default 4ac pre-ignition
    The story
    The old 4ac died so i did a swap for a reco'd one that came with an electronic dizzy, everything is wired up and running i even went and got a new radiator
    The problem
    when i turn the car off the engine the car wants to keep going. its getting to the point where i have to stall my car on purpose just to get the engine to stop
    i did the tappets they're fine, timing light said it was fine, i ran a bottle of carby cleaner through with a full tank of unleaded.
    what is the problem? spark plugs? ignition leads? carby settings?
    any help would be much appreciated. because im outta ideas
    Veteran biggo's Avatar
    Nick
    Noosa
    Your fuel is igniting on its own. Usually caused by burnt carbon that red hot.
    Try some carby settings, 98 ron fuel and check the timing again.
    Maybe pull the electrionic dizzy out and swap it for a normal one?
    Senior Member Dylan's Avatar
    Dylan
    mine used to do this. Was just a little too much advanced
    Jonathan
    It is a broken O-ring on the fuel cut-off switch, or "anti-deiseling" switch.
    Look for a 12v ignition wire going to the carby. One of these wires goes to a solenoid on the carby. Turn the ignition on and off and you will hear it click. Unscrew it with a 12mm spanner, and look at the tiny O-ring on the end of it. You need a new one.
    The broken O-ring is letting fuel pass by it even when it is turned off.
    Seb
    do i need to buy genuine toyota solenoid or can i get one that will fit from the wreckers?
    Quote Originally Posted by Aezion View Post
    Mine wasn't working either.. I took it to my carby guy and he had a spare part for it lying around so I don't think it'd need to be genuine toyota.
    Jonathan
    Most often the solenoid will work if the 1 wire is connected to ignition. The common problem is the mini o ring needs to be replaced.
    As said, fairly easy to find another off a different carby.
    Seb
    cheers guys ill have play around with it and see how i go
  1. Pre xmas clean out
    By cracker in forum Other Items for Sale
    Last Post: 18th December 2012, 04:05 AM
  2. ae86 4ac electronic ignition
    By DR86FT in forum Technical - Questions
    Last Post: 10th December 2012, 11:55 AM
  3. 4ac ignition coil wiring
    By biGtai in forum Technical - Questions
    Last Post: 16th April 2009, 12:57 AM
