i put 2 of these in my vr ss went from 106db to 81db lol
but the problem with steel wool is if you get it wrong and it happens to pop out during the test you get your shit handed to you, this is a semi permanent fix and works really well and cost about as huch as steel wool just takes a little longer
if I could trade kids for cars, I'd be turning the little critters out one every nine months.
yeh, well keep in mind that db is a logarithmic scale so the further you go down the easier it is to shut-up
that is a massive difference in Db i didn't know it made that much thanks for the stats im keen on making 1 now for my report
the dyno pull to 300rwkw
yep steel wool an a bit of coat hanger wire an 2 holes at the end works a treat also! no need to get under the car either for the lazy man
My 4agte hatch
http://www.ae86drivingclub.com.au/fo...ead.php?t=8583
my 70 wagon
http://www.ae86drivingclub.com.au/fo...ead.php?t=9525
my NA 86
http://www.ae86drivingclub.com.au/fo...s-2nd-sprinter
My Indonesian KE70 DX
http://www.ae86drivingclub.com.au/fo...nesian-KE70-DX
only problem with that is often when they do the brake test and take your car for a flog they can pop out and then they will become suspicious as to why its happened.
this is the safe and legal way to do it, someone on rollaclub said its illegal in theyre state as anything that is removable is illegal, these arent classified as illegal as they are bolted in and a part of the system.
the inpectors were onto that a long time ago.. they know all the tricks.. thought this idea seems like a good one.
good post
ill be doing this to pass my engineers certificate for sure! good idea.
good to hear it, ive passed mine with it and now i just have to wait for the registration to pass and illl be taking it back out
lol i jammed flyscreen mesh before the muffler (packed right in). work for a bit but this is so much easier and effective!
