There's a gb on club4ag for rebuild kits 300+ postage would be good considering the exchange rate. Think i might do this
thats what i couldn't piece together. which ratios the gts, sr5 ect came with?
probably will be around the $400 mark after shipping and everything
shipping is only $15+paypal fees
so should be around 350 which isnt too bad
Tis a good buy, I paid $450ish when the exchange was at 80ish.
Maybe i'll buy another
did you install it or did you pay for it? trying to work out how much it would cost to install
I just bought the kit, not fitted yet.
Can anyone confirm this?
83' 4AGTE Hachi - 335whp @ 22psi on United E85.
Never ending build...
Yep, that's my rebuild. I can confirm it.
GT-S = 19 tooth driven (plastic) gear, 5 tooth drive (on the trans output shaft) gear
SR-5 = 20 tooth driven gear, 6 tooth drive gear.
GT-S final drive = 4.3:1 ratio, T-series 6.7".
SR-5 final drive = 3.9 (manual trans) or 4.1 (auto trans), S-series 6.38"
Andrew
Bearings: retail prices
90365-30020 input shaft $253
90363-25017 output shaft $95.15
90365-20004 front layshaft $258.50
90365-20001 rear layshaft $195.80
90369-30027 centre output shaft
90365-30015 centre layshaft
I have measured the bearings and it seams none of them are regular off-the-shelf bearings. I can get the syncros from Toyota no problem.
I just want some bearing at a reasonable price. Does anyone have any ideas?
