I've got a slight drama in my engine rebuild.
I bought a 4AGE 20v Blacktop (from the AE111) but at some stage the TPS has been removed AND the little blade inside that turns the TPS. (see below)
I had a JDM RWD 16v Bigport manifold, and a ADM FWD 16v Smallport manifold... both complete with TPS.
But not only do neither blades from those line up, the TPS itself rotates in the wrong direction!
The 16v TPS turn clockwise (because when the throttle opens, the blade turns anti-clockwise)
However the 20v TPS needs to turn anti-clockwise, as when the throttle opens the shaft turns clockwise!
So I'm after a replacement TPS and blade, much like this.
According to ToyoDIY the part number for the AE111 was 89452-12090, however the AE101 was 89452-12080... and apparently 89452-22080 will also work.
I've checked all my local wreckers, but none have any of the engines that came with that TPS.
Going from ToyoDIY, the 2JZGTE, 3RZFE, 2RZFE & 5VZFE all use 89452-22080.
So if anyone has a dead engine, or a spare throttle body complete with TPS... or even know of one at their local wreckers... It'd be a great help!
Thanks
i have these in stock 100 for the tps and 10 for the linkage and 5 for postage
