Results 1 to 10 of 12
Thread: lock comparison s13 gear vs ps arms
    Senior Member worked's Avatar
    ed
    tas
    wynyard
    Default lock comparison s13 gear vs ps arms
    i'm just interested in the difference, and what your thoughts are on either set up
    opinions would be greatly appreciated, as would pics
    cheers
    NEAR MISS
    Nathan
    Lilydale
    also interested in this, i have a feeling ps arms may give more lock.... some proof would be sweet.
    Also has anyone ran s13 with a rack spacer? would like to see also.
    Ferny Grove
    S13 lock is determined by the steering knuckle hitting the LCA, a rack psacer can't change this, its still going to hit the LCA.
    that was the case in my old setup
    Nathan
    Lilydale
    what if you were to remove the steering stops on the lca?
    Veteran slydar's Avatar
    Dimitri
    yeah general oppinion is s13 you end up with a bit less than with p.s arms. but its still pretty workable (lock wise).
    Mt Macedon
    I had two Sprinters.
    One with S13 front setup, lock limited by knuckle/tie rod hitting the LCA (MX62). One stock aside from PS arms.
    And after 6 months of driving them back to back I am sure that PS arms give more lock. I especially noticed as I often had to do a U-turn out the front of my house to find a park.
    ed
    tas
    wynyard
    ideal, how come pidwell has soo much lock then???
    NEAR MISS
    Senior Member Simon-KE70's Avatar
    Simon
    because he uses S13 crossmember and rack set up (actually uses an S12 rack but thats a moot point)
    the fact is kids, if you want shit to work, dont mix and match - ie running s13 susp with AE86 crossmember and steering does not work WELL.
    ed
    tas
    wynyard
    interesting... but your saying using the s13 x member and therefore the rack etc works better?
    x member is a fairly easy install isn't it?
    NEAR MISS
    Simon
    yeah it works a shit load better, since the rack is in the right position to suit the steering arms on the nissan hubs, so it all works either each other and the tie rods and LCA are parallel where as with toyota rack and X member they are crossed up.
  1. PS arms and lock spacer install
    By GEMTA22 in forum Sydney & NSW Events and Discussion
    Last Post: 7th December 2009, 12:33 PM
  2. 86 ps arms, get yo lock own
    By shift_rook in forum Car Parts For Sale
    Last Post: 26th October 2009, 10:29 AM
  3. PS Arms, XT130 LCAs and Lock Spacer
    By Lost Prophet in forum Car Parts For Sale
    Last Post: 22nd July 2009, 06:21 PM
  4. 35mm RCA's, PS arms, lock spacer
    By seeknsqueek in forum Cars or Parts Wanted
    Last Post: 3rd November 2007, 02:35 PM
  5. Steering Lock - Quaife Rack, PS Arms, Tie Rods, Tie Rods Ends
    By SoKAR in forum Technical - Articles
    Last Post: 26th August 2007, 09:18 PM
