Dead AFM?
AW11 engines are all AFM right?
engine is stock apart from filter and 2"5inch exhaust aw11 bluetop in a ae70
problems are
spark plugs go black with carbon no black smoke out exhaust tho
hesitation/splutter when jab throttle open
timing doesn't advance when engine revs increase
engine only runs for a second no matter what you do when the T and E1 are shorted out
things i have tried
have tried 2 different MAP sensors
replaced plugs
checked TPS
and tested MAP TPS wiring from plugs to ecu
Thanks
Dead AFM?
hi thanks for the reply this has a MAP sensor
it was a dead ecu that was the problem
