found this on
dont go off the part numbers, just the oil grades
1983 TOYOTA COROLLA 1.6L 4-cyl Engine Code [A] 4A-C
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......API*
AMSOIL European Car Formula 100% Synthetic 5W-40 Motor Oil (AFLQT)
XL 10W-40 Synthetic Motor Oil (XLOQT)
Above -12C......20W-40, 20W-50
Above -23C......10W-30, 10W-40, 10W-50
Below 10C......5W-30
Manual Transmission,RWD......GL-4
All TEMPS......75W-90, 80W-90
Synthetic Manual Transmission and Transaxle Gear Lube (75W-90) API GL-4 (MTGQT)
Manual Transmission,FWD......GL-5
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
Manual Transmission,RWD......GL-5
Manual Transmission,FWD......GL-4
Automatic Transmission,A41......FA
Synthetic Supershift Racing Transmission Fluid SAE 10W (ARTQT)
Automatic Transmission,A40D......FA
Differential, Front 4WD......AF3 [1]
ALL TEMPS......
Synthetic Universal Automatic Transmission Fluid (ATFQT)
Torque-Drive Synthetic Transmission Fluid (ATD1G)
Controlled Slip Differential, Rear RWD......GL-5*
Above -18C......90
SAE 80W-90 Synthetic Gear Lube (AGLQT)
Standard Differential, Rear RWD......GL-5
Above -18C......90
Below -18C......80W-90, 80
Fluids
Power Steering Fluid......AF3
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN)
Clutch Fluid......HB
[1] Final drive for Automatic transmission only.
FILTERS:
Oil Filter MANN 7500-Mile Oil Filter (ML1009) [1]
Air Filter WIX 46007 Air Filter
Fuel Filter WIX 33275 Fuel Filter
Transmission Filter [2]
Transmission Filter WIX 58915 Auto Tran Filter [3]
[1] Guaranteed up to 7500 miles when using AMSOIL motor oil.
[2] was # 58910 now Obsolete - 3 Speed
[3] 4 Speed
NGK PLUGS AND WIRESETS:
GPSERIES PLUG BPR5EGP
IXIRIDIUM PLUG BPR5EIX-11 NGK2115
PREMIUMPLATINUM PLUG BPR5EP-11 *
STANDARD PLUG BPR5EA-L-11 # NGK7532
VPOWER PLUG BPR5EY-11 NGK6937
WIRESET WIRESET RC-TX03 NGK9993
WIPER BLADES:
Blade Class Driver Passenger Rear
ExactFit T193 T173 T173
Winter T37190 T37170 T37170
CHASSIS LUBRICATION:
FWD
0 Fittings, 0 Plugs
RWD
0 Fittings, 2 Plugs..........LM
Series 2000 Synthetic Racing Grease NLGI#2 GC/LB (GRGCR)
Synthetic Heavy-Duty Grease NLGI #2 GC/LB (GHDCR)
Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLCTB)
CAPACITIES:
Engine, without filter..........3 liters [1]
Engine, with filter..........3.1 liters [2]
Cooling System, RWD Initial Fill..........5.5 liters
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, A40D Initial Fill..........2.4 liters
Automatic Transmission, A41 Initial Fill..........2.4 liters
Automatic Transmission, Total Fill
4 speed A40D..........5.7 liters
3 speed A41..........6.3 liters
Manual Transmission, RWD..........1.7 liters
Manual Transmission, FWD..........2.5 liters [3]
Differential, FWD With 3-SPD AT Front..........1.4 liters [4]
Differential, With CS Rear..........1.3 liters
Differential, Without CS Rear..........1 liters
[1] Add extra oil when replacing filter. After
refill check oil level.
[2] After refill check oil level.
[3] Capacity includes final drive.
[4] Final drive with 3 speed Automatic transmission only.
TORQUES:
Oil Drain Plug.....FWD......25 ft/lbs
Manual Transmission
Fill Plug 36 ft/lbs
Drain Plug 36 ft/lbs
