Results 1 to 10 of 10
Thread: 2t, 3t questions
    Veteran shift_rook's Avatar
    SE Burbs
    Default 2t, 3t questions
    well i've located a 2tg head and i'm thinking about chuckin it on my 3tc block, couple of questions...
    1. will i need to have an electronical fuel pump??
    2. what timing belt will i need??
    Senior Member stouty's Avatar
    Leigh
    Forster
    Also keen as to find out more about doing a 3tg conversion. Have looked around a bit but cant seem to find a good detailed step by step description.
    Grip TE72
    http://www.ae86drivingclub.com.au/fo...read.php?t=276
    AJPS for all you Toyota goodies
    SE Burbs
    also anyone got a spare 2t manifold and carb, this is the only bit that's makin me hesitant on gettin it, parts ar emoderately hard to come by???
    Elite rthy's Avatar
    Leo
    Tulla
    check on toymods
    Jonathan
    I have built a tough 3T-G and used it for many years.
    For the motor itself, you are best to start out with a complete 2T-G twincam motor. Because it you get the head, you still need the dummy cam and dummy cam sprocket. And a few other twincam parts make it nicer.
    For a "3T-G", you need:
    2T-G twincam head, including cams and buckets etc
    2T-G thermostate housing
    top chain tensioner (I have one spare)
    cam sprockets
    top chain (can get this new)
    2T-G specific dummy cam, and sprocket
    top chain guides (very hard to buy new)
    2T-G specific front timing cover (hard to find)
    bottom chain and tensioner (can get new, same as 2T/3T)
    3T crank
    3T pistons, modifyed
    rotate unused camshaft bearings in the block to blockoff oil holes
    2T-G dizzy is longer than singlecam one, but can use single cam one.
    use 2T or 3T waterpump, block off one hole for 2T-G spec.
    Then you decide between EFI or carbies...
    For carbies, you use a stock mechanical pump from any 3T-C or 2T.
    I have a pair of carbies to sell, but no manifold.
    Jonathan
    No timing belt. They are chain. Big fat double row chains, 2 of them. You can buy them new. Generic chain that can be made your length from a local machine shop. The bottom chain can be ordered new as a kit to suit 3T-C.
    Calvin
    Kilsyth
    yeh what he said
    would be a nice little motor in your car chris. VERY tough motor. can't kill them
    SE Burbs
    but if i can't find an exhaust of manifold to suit what's the point??? would absolutely love one but yeah
    Jonathan
    The same exhaust manifold and gasket fits either 2T-G or 2T or 3T-C. So you have a choice of a old cast iron one, or aftermarket extractors which used to be a very common on the shelf item. (Listed to suit either TA22 Celica, or TE72 T-18).
    Jonathan
    Just to confirm, you can chuck the 2T-G head on a 3T bottom. BUT, you need to disassemble both engines down to every last nut and bolt before you put the hybred back together. Valve clearance needs to be machined in the exhaust side of the 3T pistons. (Use a 2T-G piston to copy).
    3T headgasket can be used if you get creative in filling the front timing cover gap. Just in case the 2T-G head gasket costs too much. I have done it before.
    The best intake manifold gaskets are the ones you have yourself from cerial packet.
  1. Replies: 0
    Last Post: 11th April 2012, 08:05 PM
  2. Adelaide: 2T-G, 3T-C T50, T18 Struts, Tailshafts, Wheels
    By dAYTONA in forum Car Parts For Sale
    Last Post: 14th January 2010, 01:43 PM
  3. [vic] 2t/3t Hybrid Out Of A Ta22
    By PULSE in forum Car Parts For Sale
    Last Post: 3rd May 2008, 04:03 PM
  4. Lynx Single Sidedraught Manifold for 2T/3T SOLD
    By floody31 in forum Car Parts For Sale
    Last Post: 27th April 2008, 09:47 AM
  5. 2t / 3t Hybrid Forged Pistons
    By willie in forum Car Parts For Sale
    Last Post: 21st August 2007, 12:22 AM
