Results 1 to 10 of 11
Thread: putting a/c in 4agze
    Veteran evil86's Avatar
    Phuoc
    Liverpool
    Default putting a/c in 4agze
    please dont flame me but, i'd like to know who has or has put a/c in their gze. i wanna keep my a/c when i put in gze motor. can i use 4ac a/c compressor?
    性交を愛する
    You live down south. You don't need it
    Mt Macedon
    No, 4AC uses a V belt. GZE uses 5pk belts. Hopefully you can use the compressor that comes with your engine and make a couple of hoses to conenct to the AC gear on the car.
    Ferny Grove
    dude if i could have A/C i would too don't worry about flamage!!
    Hugh
    Doesnt AC have to be removed to mod an alternator bracket??
    c
    Quote Originally Posted by hugh View Post
    No. you can run the standard mount. with a/c and alt in standard position
    Quote Originally Posted by egg_83 View Post
    ^^^ yes, but in most cases the alt rubs on the front swaybar....
    Hugh
    exactly...hence the reason most gzes have modified alternator brackets
    Mt Macedon
    If you want AC you can make it work with the stock AC compressor and alternator. I ran my compressor for years even though it wasn't connected to anything simply because it all fitted and was the easiest for me.
    If you don't care then sometimes it is easier to bin the AC and make a new alt bracket.
    Phuoc
    Liverpool
    hen : so i should take the alternator and air compressor from my 4ac and put it in my gze?
  1. Replies: 8
    Last Post: 2nd April 2011, 01:18 AM
  2. still putting in my 3sge
    By ash86 in forum Technical - Questions
    Last Post: 4th November 2007, 01:11 AM
  3. Putting on a new head...
    By VeRm69 in forum Technical - Questions
    Last Post: 22nd September 2007, 08:13 PM
  4. putting pictures on site
    By fat86 in forum General Topics (No Technical Questions)
    Last Post: 22nd July 2007, 04:25 PM
  5. after putting my system in
    By drif86s in forum Technical - Questions
    Last Post: 17th May 2006, 09:46 PM
